1967 2 speed wiper system (Barracuda)
According to the parts book, the motor should be p/n 2808 767.
However the popular lists on-line suggest it may not be.
The stamping on the motor appears to begin with 28?2
(I'll try to get a better look and photo of the stampings next trip to the garage.)
Problem is when the wipers are turned off, they go to the bottom of the windshield but then travel up an inch.
According to the '67 FSM, the 'timing' of the park switch should be adjusted. Has anyone taken apart a similar motor or know where this the Park Switch timing is on the 2 speed motor?
According to my '68 shop manual, this doesn't apply to 2 speed motors. I'm guessing the '68 wiper motor operates differently.
So if my motor is not a '67, then I'd like to know that before I start taking things apart.
