One or two fore/aft engine limiters #2362385
08/30/17 04:03 PM
08/30/17 04:03 PM
Ohio
lockjaw-express Offline OP
Ohio
Street/strip 4 speed hemi 980 hp...do I need one or two fore/aft limiters?
I just installed one from the bellhousing to one of the transmission
Crossmember bolts, and is a straight shot.
Any opinions would be helpful, thank you.
Mark
Re: One or two fore/aft engine limiters [Re: lockjaw-express] #2362397
08/30/17 04:26 PM
08/30/17 04:26 PM
an8sec70cuda Offline
I just use one on my cuda and it works fine. Been that way for 10 years w/ no midplate.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: One or two fore/aft engine limiters [Re: an8sec70cuda] #2362400
08/30/17 04:31 PM
08/30/17 04:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use 2 on the race car.. it leaves hard.. on
your stick ride I would use 2 so it cant torque
the engine side ways.. JMO
wave
Re: One or two fore/aft engine limiters [Re: an8sec70cuda] #2362443
08/30/17 06:01 PM
08/30/17 06:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Same here............. thumbs
Re: One or two fore/aft engine limiters [Re: Thumperdart] #2363432
09/01/17 12:53 PM
09/01/17 12:53 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Running two on my car. No room in the engine bay with the Hemi & headers so I went off of the trans mount.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: One or two fore/aft engine limiters [Re: lockjaw-express] #2363500
09/01/17 02:34 PM
09/01/17 02:34 PM
Ohio
Ohio
Hi all,
I went with two, and since both of my cars are 4spds...I took Mike's (Mr_P_body) advice. I have one inline from the Lakewood bell to one of the Transmission Crossmember bolts, and one from the left engine mount pad with a modified old motor mount, angled back to a welded bracket welded to the frame rail. I bought the Jegs brand CM Panhard Bar kit. A little pricy, but very nice parts.
Thanks, All!
Re: One or two fore/aft engine limiters [Re: lockjaw-express] #2365308
09/04/17 05:10 PM
09/04/17 05:10 PM
Ohio
Ohio
Pictures of my installation...
Mark
Re: One or two fore/aft engine limiters [Re: 6PKRTSE] #2365622
09/05/17 03:30 AM
09/05/17 03:30 AM
Me likey that up
Thanks for the ideas bow
Re: One or two fore/aft engine limiters [Re: lockjaw-express] #2365646
09/05/17 08:42 AM
09/05/17 08:42 AM
New York
polyspheric Offline
polyspheric  Offline
New York
A mount in compression must be pretty stout - don't use a 5/16-24 bolt through the Heim joint.
A mount in tension can be (almost) a piece of lamp cord.
Boffin Emeritus
Re: One or two fore/aft engine limiters [Re: polyspheric] #2365703
09/05/17 11:22 AM
09/05/17 11:22 AM
moparx Offline
moparx  Offline
3/8-1/2" perhaps ? what about tubing material to be used ? chromoly only ?
beer
Re: One or two fore/aft engine limiters [Re: 6PKRTSE] #2365716
09/05/17 11:54 AM
09/05/17 11:54 AM
Sth.IL
dare_dude Offline
dare_dude  Offline
Sth.IL
Mine are a little shorter than this on 727. But pretty much same set up!
Re: One or two fore/aft engine limiters [Re: lockjaw-express] #2365718
09/05/17 12:00 PM
09/05/17 12:00 PM
Ohio
Ohio
I used the Chrome Moly 1/2" Heim Joints w/chrome Moly 1" x .083 tubing & has the CM threaded inserts. It is the Jegs Panhard kit that sells for just under $100.00 each, and comes with the CM stands.
The 1/2" Fine Thread bolts that come with the kit are grade 8 bolts & grade 5 Nylock nuts.
Very nice kit!
Mark
Re: One or two fore/aft engine limiters [Re: lockjaw-express] #2366121
09/05/17 11:26 PM
09/05/17 11:26 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Stiffness is almost unrelated to the steel alloy, mild is 99% of 4130, it's the diameter that matters. 1" is popular so I guess it works. Thicker wall does very little compared to going up to 1-1/4".
As a restraint in tension only, I've used 5/32" steel wire braid with thimbles and lead U clamps, never moved, weighs nothing, costs nothing, silent, easily adjustable if needed. Also makes a nice vertical restraint to prevent ripping that driver's side rubber mount.
Boffin Emeritus
Re: One or two fore/aft engine limiters [Re: lockjaw-express] #2366160
09/06/17 12:20 AM
09/06/17 12:20 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I use one in the front. It's actually aluminum. There is a bracket that bolts to the pan rails that is hard to see in pic.
I concur, I'd rather have it in tension.
