FI-Tech Go EFI 4 Problems #2362162
08/30/17 06:14 AM
08/30/17 06:14 AM
Germany
rubberduck Offline OP
Germany
Finally I got all hooked up. I use a gastank from Tanksinc. with an internal fuelpump.
Yesterday I started the engine the first time with the FI Tech Go EFI 4.
Starting was a little hard. The idle is way to low and it smokes like it is running too rich.
I turned in the screw on the throttle body as discribed. I tried several times. one time it ran smoothly with no smoke.
The throttle response was very quick. But then idle went down to 450 rpm and it started to smoke again.
Now I don´t know what to do.
The engine is a 505 cui.
I guess I have to do some calibration.
Below you can see pics of the controller. There are so many parameters you can change that I don´t know about.
Maybe that is the reason.
Also I have attached the white cable (to ignition) to the ballast resistor as you can see in the first pic. Is that okay?
Mario
Re: FI-Tech Go EFI 4 Problems [Re: rubberduck] #2362194
08/30/17 10:11 AM
08/30/17 10:11 AM
NY
F1Scamp Offline
F1Scamp  Offline
NY
Just got done installing one of these systems on a customers car. There is very little information out there on the tuning side, you kinda have to fumble through it. Hook up a fuel pressure gauge and check the fuel pressure. The regulator that came with the tanks unit (albeit for a chevy) was junk and could not bypass enough fuel. It needs to see a pretty consistent 50-60psi (58psi is spec.). What is your IAC Step's at warm idle?
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
Re: FI-Tech Go EFI 4 Problems [Re: rubberduck] #2362196
08/30/17 10:12 AM
08/30/17 10:12 AM
NY
F1Scamp Offline
F1Scamp  Offline
NY
You also cannot use a ballast resistor ignition system if you are using the Fitech to control ignition.
Re: FI-Tech Go EFI 4 Problems [Re: F1Scamp] #2362217
08/30/17 10:55 AM
08/30/17 10:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Add in more timing also.. 10* wont make it
wave
Re: FI-Tech Go EFI 4 Problems [Re: F1Scamp] #2362223
08/30/17 11:03 AM
08/30/17 11:03 AM
Germany
Germany
Right now I´m not using the timing control.
Re: FI-Tech Go EFI 4 Problems [Re: F1Scamp] #2362225
08/30/17 11:03 AM
08/30/17 11:03 AM
Germany
Germany
Okay. I will get me a fuel pressure gauge to check this.
Re: FI-Tech Go EFI 4 Problems [Re: MR_P_BODY] #2362227
08/30/17 11:07 AM
08/30/17 11:07 AM
Germany
Germany
wave
Okay, I`ll try 15°
Re: FI-Tech Go EFI 4 Problems [Re: rubberduck] #2362322
08/30/17 02:15 PM
08/30/17 02:15 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
Vacuum or exhaust leaks will cause it to run rich (O2 sensor is seeing more air so is dumping more fuel). Mine was doing that and my plugs were fouled out pretty quickly. Do you have Facebook? There is a good group of people to help on there. I ran my white wire right to the battery while I figure out the system. I did have it hooked to my electric choke wire but will probably hook it up to a switch inside the will then go to the battery, will be a good killswitch also.
Are you getting any fault codes? What ignition set up do you have?
Re: FI-Tech Go EFI 4 Problems [Re: rubberduck] #2362352
08/30/17 03:01 PM
08/30/17 03:01 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I've had the Go EFI 8 on my 493" for 18 months, 5-6k miles and dozens of passes.
What steps have you gone through? I'll say the instructions aren't the greatest, but it really isn't that complicated either...
I just checked voltage to see what circuits had 12V wih key on and while cranking. I used the same circuit that was going to my MSD box IIRC.
If you aren't controlling the timing, then the timing settings don't matter.
What are the specs on your cam?
Overlap will cause the O2 sensor to see excess O2 and it will add fuel
What ignition system are you running? What is your timing set at?
I have the FITech controlling timing feeding a MSD 6AL. Cranking is 20 deg adv, idle is 30 deg.
How do you have the tank/regulator set up?
I am running full return using the FITech regulator. It will support a 340LPH pump, but not more.
I would leave most of the settings alone until you get some drive time
The unit has an IAC solenoid to control idle, but getting the "idle screws" adjusted correctly is important. You want the IAC steps between 6-10 with the engine hot, in gear. Adjust the idle screw to achieve this. to get more air while cranking, you have to increase the "cranking IAC multiplier"
this PDF is helpful:
http://fitechefi.com/fitech-uploads/2016/07/HandheldcontrollerfeatureDefinitions.pdf
once you get a little further I can maybe try to help a bit more, but my system fired up no problem (although I have had other problems...haha)
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: FI-Tech Go EFI 4 Problems [Re: rubberduck] #2366294
09/06/17 11:26 AM
09/06/17 11:26 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Any update on this?
