A-500 in my 2002 Dakota
#2360513
08/27/17 11:11 AM
08/27/17 11:11 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
The trans hasn't been acting up at all....while I slowed down for a light, the motor just revved up like nobody home. I manually tried shifting it and 1st would work....so I got home & didn't drive it for awhile.
Got it in my shop trying to do the cheap way out and dropped the pan.
Didn't look bad at all....changed filter, blew out the trans lines going to the radiator. To make sure that one way valve wasn't plugged and it wasn't.
While I was in there I found that the accumulator spring was broke(didn't think that that was the problem), but changed it anyways...had one in another trans.
I've noticed after all of the above and back driving it that if I can get it in to second gear it'll shift just fine all they way to OD without slipping in any gear....just getting it out of first seems to be the deal.
Any help would be greatly appreciated.
Thanks.
Lee
Moparlee
Re: A-500 in my 2002 Dakota
[Re: Robbins]
#2360551
08/27/17 12:51 PM
08/27/17 12:51 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
The RE series of trans, which is 96 and newer, has issues with the electronics on the valve body. Lots of issues on the 44, 46 and 48 versions in the bigger trucks. There are updated replacement parts, check out the diesel forums. And since you said its a 500, I'm assuming its behind a 3.9 V-6? The 5.2 [44re maybe] & 5.9 used the 46, if you have a 4.7 or the v6 version 3.7, you have a totally different trans.
Carl Kessel
[Re: Robbins]
#2360665
08/27/17 05:00 PM
08/27/17 05:00 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Make sure the TP (top) lever on thee trans is returning to full forward at idle.
[Re: CKessel]
#2360722
08/27/17 07:06 PM
08/27/17 07:06 PM
Robbins
Joplin, MO USA
The RE series of trans, which is 96 and newer, has issues with the electronics on the valve body. Lots of issues on the 44, 46 and 48 versions in the bigger trucks. There are updated replacement parts, check out the diesel forums. And since you said its a 500, I'm assuming its behind a 3.9 V-6? The 5.2 [44re maybe] & 5.9 used the 46, if you have a 4.7 or the v6 version 3.7, you have a totally different trans. 3.9 904 style pan
Moparlee
[Re: John_Kunkel]
#2360723
08/27/17 07:08 PM
08/27/17 07:08 PM
Robbins
Joplin, MO USA
Ok, it does have a spring on it I noticed when I was under it. Like I said the trans isn't slipping like I first had thought....once I get in second it shifts fine. When I say....get to go in....I got to floor it and then let out and it might go or not go, but once it does it shifts like it supposed too. Thanks....again.
Moparlee
[Re: Robbins]
#2361213
08/28/17 04:45 PM
08/28/17 04:45 PM
John_Kunkel
Rio Linda, CA
Even with the spring installed the cable/linkage can bind up and cause delayed shifting. Disconnect the lever and be sure the lever goes full forward then drive gently to see if the 1-2 shift delay is still there.
[Re: John_Kunkel]
#2362187
08/30/17 09:30 AM
08/30/17 09:30 AM
Robbins
Joplin, MO USA
Ok...I haven't been able to get back on it yet....to play with it. I'll check all this out. Thanks.
Moparlee
[Re: Robbins]
#2375752
09/24/17 12:20 AM
09/24/17 12:20 AM
Robbins
Joplin, MO USA
Ok.....finally got back on this...the governor sensor was bad. Driving like it should....thanks for all the help guys.
Moparlee
