Re: Motor Mount (Rubber Isolater) [Re: bee1971] #2361912
08/29/17 08:23 PM
08/29/17 08:23 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Originally Posted By bee1971
With no description how is one to know that that isn't just a store mount?
Re: Motor Mount (Rubber Isolater) [Re: Jim_Lusk] #2361917
08/29/17 08:34 PM
08/29/17 08:34 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
It does look like it has the bolt through it.
Re: Motor Mount (Rubber Isolater) [Re: Jim_Lusk] #2362145
08/30/17 03:26 AM
08/30/17 03:26 AM
Sobieski Wi
bee1971 Online work
bee1971  Online Work
Sobieski Wi
MAGMOUNT HEAVY DUTY ENGINE MOUNTS
MAGNUM MOUNT-PROTECTS AGAINST INSULATOR BLOW-OUT.
Available for biscuit-style A engine swaps and replacements. '63-72 A-Body, '66-72 B, '66-73 C, and '70-74 E.
Bolt-through design locks up under acceleration, prevents blow-outs - provides the durability of a solid mount without sacrificing the smooth ride of rubber.
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2362256
08/30/17 12:03 PM
08/30/17 12:03 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
If it is bolt thru design, then why not get regular mount and drill it out and put your own bolts thru it ?? Would be less $$$ ???? Just a bit more work . . .
Re: Motor Mount (Rubber Isolater) [Re: a12rag] #2362364
08/30/17 03:28 PM
08/30/17 03:28 PM
dogdays Offline
dogdays  Offline
If that's how you want to roll, go for it!
R.
