Removing the instrument cluster in a 69 road runner #2358743
08/23/17 08:22 PM
08/23/17 08:22 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I was wondering if anyone can give me a quick tutorial on how easy or difficult it is to take out the instrument cluster on my 69 road runner. I had the speedometer and complete cluster rebuilt about 10 years ago and the speedometer never worked right from the day i got it back. After taking to the place in Florida that did the work the only thing they could tell me was to send it back and I really did not want to send it back after waiting 6 months way back then. Now i want to address it so i can get it and the odometer working again. I think the speedometer head is the issue and i want to get it out to see if it's something i can do on my own to fix it. When it was hooked up again today by the shop that is doing the motor install and the mechanic said it started running backwards. So he wants to take out the cluster and see what he can do to fix it. He had a new cable made to fit the 4L60 trans so he knows it not the cable.
Thank you for any advice.
Stu
Re: Removing the instrument cluster in a 69 road runner [Re: MidPenMopar] #2358858
08/24/17 12:17 AM
08/24/17 12:17 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Its no easy task. The best way in my opinion is to take out the drivers front seat so you can lay on the floor.
disconnect all the switches
unscrew the switch panel from the front
unbolt the lower dash pad and remove it and the switch panel
now you can access the cluster screws (there are two at the top)
When you reinstall everything, getting the switch panel in is virtually impossible with the switches installed. This means installing the lower pad, installing the panel then installing the switches from the back - fun, fun, fun. You might want to pull out the steering column !!
Re: Removing the instrument cluster in a 69 road runner [Re: Stanton] #2358864
08/24/17 12:32 AM
08/24/17 12:32 AM
Oh crap............ pity
Re: Removing the instrument cluster in a 69 road runner [Re: MidPenMopar] #2358868
08/24/17 12:33 AM
08/24/17 12:33 AM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
I'll politely disagree, Not that bad depending on ones size and flexibility. In my younger days 10- 15 minutes with a bit of practice. I'll agree having the seat out helps smile
OK, myself I would first try to identify whether the issue is with the Speedometer / head or the Cable / Routing.
Easily accomplished with a short test cable and drill motor hooked up to the head. FYI a 1000 RPM should = 60 MPH.
When it was hooked up again today by the shop that is doing the motor install and the mechanic said it started running backwards. ???
The mechanicals are like a garage door STU, IMPOSSIBLE unless the ???
Re: Removing the instrument cluster in a 69 road runner [Re: MidPenMopar] #2358870
08/24/17 12:35 AM
08/24/17 12:35 AM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Pull the column ?? B-------t, loosen and lower it, yes
Re: Removing the instrument cluster in a 69 road runner [Re: TJP] #2358891
08/24/17 12:52 AM
08/24/17 12:52 AM
He did that with an electric drill and came up with the idea the head is bad, as when he tested the spedo with a drill he had to have the drill in Reverse to make the needle move correctly. That's the confusing part of this whole thing. I am picking up the car tomorrow afternoon so i will see if he made any more progress during the day. Thank you for the advice.
Re: Removing the instrument cluster in a 69 road runner [Re: MidPenMopar] #2359017
08/24/17 09:55 AM
08/24/17 09:55 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
IIRC it spins backwards
Re: Removing the instrument cluster in a 69 road runner [Re: Morty426] #2359086
08/24/17 12:59 PM
08/24/17 12:59 PM
Oh so than that is correct that the the spedo cable needs to run in reverse to push the needle forward?
Re: Removing the instrument cluster in a 69 road runner [Re: MidPenMopar] #2359093
08/24/17 01:06 PM
08/24/17 01:06 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Yepper
Re: Removing the instrument cluster in a 69 road runner [Re: 1E2C] #2359120
08/24/17 01:42 PM
08/24/17 01:42 PM
Originally Posted By 1E2C
Yepper
Thank you!!!
Re: Removing the instrument cluster in a 69 road runner [Re: MidPenMopar] #2359205
08/24/17 04:29 PM
08/24/17 04:29 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
There is a speedometer place in Old Town Portland OR... You might try them for a quicker turn around??? Good people.. I will try to find the name... maybe Bee knows em???
Re: Removing the instrument cluster in a 69 road runner [Re: minivan] #2359211
08/24/17 04:41 PM
08/24/17 04:41 PM
Thank you for any links to that.
Re: Removing the instrument cluster in a 69 road runner [Re: MidPenMopar] #2359219
08/24/17 04:55 PM
08/24/17 04:55 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Lets hope this pastes...
http://www.speedometerserviceportland.com/
Re: Removing the instrument cluster in a 69 road runner [Re: minivan] #2359224
08/24/17 05:06 PM
08/24/17 05:06 PM
Got it thank you!!!
Re: Removing the instrument cluster in a 69 road runner [Re: MidPenMopar] #2359255
08/24/17 06:17 PM
08/24/17 06:17 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Stu,
might give these guys a call as they are close to you,
http://www.paspeedo.com
beer
Re: Removing the instrument cluster in a 69 road runner [Re: TJP] #2359258
08/24/17 06:37 PM
08/24/17 06:37 PM
Stu,
beer
Thank you, that's right in my area!
Got the car back and so far so good! Just have to use my GPS to track the millage and speed now.
Re: Removing the instrument cluster in a 69 road runner [Re: MidPenMopar] #2359326
08/24/17 09:12 PM
08/24/17 09:12 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Being from SMOG JOSE I knew they were grin
Used to go there years ago
Re: Removing the instrument cluster in a 69 road runner [Re: TJP] #2359624
08/25/17 01:28 PM
08/25/17 01:28 PM
Hello Stu, it's been awhile, I been real busy sharpening drill bits for the CIA. I ain't sure how you would go about knowing the drill speed to calculate that so what I would do is spin your current speedo and another one as fast as the drill will go & see if they (both) read the same (drill in reverse as said). If there is a way to know drill speed (I might call the mfr) as I preoiled a 360 a few days ago & only got 35 psi & the "crank" RPM is gonna be double that of the drill speed (which don't look good for enough psi at this point.)
Re: Removing the instrument cluster in a 69 road runner [Re: RapidRobert] #2359936
08/25/17 10:44 PM
08/25/17 10:44 PM
Hummnn??? laugh
