Re: Magnum conversion harness.
[Re: 4speeds4me]
#235883
04/20/10 12:13 AM
04/20/10 12:13 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
Is this process likely to be easier or more difficult with the pre-Magnum 318? I have a FI 318 out of a 1990 PU that Dad was thinking about using in his 56...
a pre magnum,,318 is a standard LA 318, standard manual fuel pump,and carb, electronic distributor,,,not much to it, and no computer to deal with
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#235885
04/21/10 08:44 AM
04/21/10 08:44 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
'88 they switched from carb to a holley EFI in trucks.
[Re: patrick]
#235887
04/26/10 03:35 PM
04/26/10 03:35 PM
fstfish66
levittown pa
also in 88 the 318 went to a roller cam, basically a mangnum engine, i think with still only 5 valve cover bolts,,,in 89 the 360 went roller cam,,magnum engine, and i believe still 5 bolt valve covers,, with the high swril heads?? not sure what style rockers
[Re: fstfish66]
#235888
04/28/10 06:41 AM
04/28/10 06:41 AM
patrick
Grand Haven, MI
they were both LA heads. the 318 went to 302 heads from ~85-91 and the 360 used 308's from 89-92. both use shaft rockers. magnums with their AMC V8 style pedestal rockers didn't come out until '92 (318) and 93 (360)
[Re: volaredon]
#235890
07/17/10 02:55 PM
07/17/10 02:55 PM
fstfish66
levittown pa
ok any one have any thoughts???
im looking to replace the old style dodge red ram hemi in my rod i think,,,,
i located a 5.2 test mule engine from a guy that use to or still does?? work for chrysler,,says this engine would have less then 12000 miles,,but was never in a street vehicle,,pics of it looks like new,,have not gone to se it yet,,
1997 5.2 complete,with alt,a/c compperssor,mech fan,,flex plate,,exhaust manifolds,engine harness...,etc,,
says he will throw in a J-TECH computer says same computer as in a dakots/jeep cherokee,,etc,,
my rod had a 318 in in once upon a time,,and i want to re use my 904 (999 low 1st gear)tranny,,
question notching the bell housing for the pick up????
converting my mopar external voltage regulator to use the magnum alternator with internal regulator ???/
converting my engine harness to work with my already wired car,,????
use a vette fuel filter with return line built in,,,????
a guy i have met has same car,,used a buick road master wagon fuel tank with intake fuel pump,,
this motor has the Y pipe with single O2 SENSOR im sure the Y pipe wont fit,,but can weld a bung on my current dual exhaust???
any thing im missing??? any ideas??? do.s or dont,s ???? thanks in advance,,,
the guy that reworks these harneses have you done any yet and seen that they fire the engine??
does the computer need reflashing????
ive since talked to in person the hot wire people,,,they no longer sell to street and performance,,
[Re: dodgedartgt]
#235892
03/13/13 04:19 PM
03/13/13 04:19 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
Yes I build one for 250 plus shipping back to your house if you supply the harness or 300$ if I supply the harness. It will only engine, and trans (but only if usuing the older 4 speed overdrive 46rh) unit.
I have done three harnesses and working on 4 & 5 now.
You would need a 143 tooth flywheel that has the notches for the crank sensor. Or a custom 130 tooth flywheel made, if you need the small diameter!
Let me know if I can help!
Justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: wldtm]
#235893
03/18/13 08:12 PM
03/18/13 08:12 PM
Posts: 234 SW FL
dodgedartgt
SW FL
Hi Justin,
Thnx for the reply. I will want to do this, probably over the summer. I already have a harness from a '93(?) 5.2, but I seem to recall that I busted one of the injector connectors while I was removing it. Again, my plan is to back it up with a clutch, so I'll be using the AX15 bellhousing, so I have provision for the crank position sensor.
Originally, I planned on putting an AX15 behind a Magnum headed 360, so I already have the 143 flywheel from a 3.9, knowing it would need to be rebalanced. (I already understood the flywheel balance factor on Magnum blocks is different than that of same displacement LA blocks.) I suppose I'll have to get the appropriate 5.2 or 5.9 flywheel to move forward with this planned project.
Thnx much, Mike in FL
[Re: dodgedartgt]
#235894
03/19/13 03:55 PM
03/19/13 03:55 PM
wldtm
Dayton, Ohio
In reference to your question about the 5.2, flywheel, yes you would need a flywheel for a 5.2, the 3.9 does not have the correct number of notches. A 5.9 flywheel is only used with a 5.9 do to being externally balanced.
PM me if you have more questions!
Justin
PM for details
[Re: wldtm]
#235895
03/23/13 10:11 PM
03/23/13 10:11 PM
Posts: 234 SW FL
dodgedartgt
SW FL
[Re: wldtm]
#235896
05/17/13 10:31 PM
05/17/13 10:31 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
Justin, my son just picked up a 64 dodge wagon with a poly in it and we got to talking engine swaps and he wants to take the 5.2 engine and od trans I have here from a 93 dakota and use it in the wagon. do you still have a harness that would work with this setup. he said he could get a new MP computer for it. we wondered what would be needed to use the od trans(just a push button switch)??? we know we would have to do something about the fuel pump and a return line. can I give you a call sometime and iron out some details thanks Ron...
[Re: Flipper1938]
#235898
05/19/13 04:12 PM
05/19/13 04:12 PM
Mopar Ron
After reading threads like this, I understand why people stick 350 chevy motors in mopars!
yeah but I would still go through all the B.S. just to not have a chevy in a mopar
a lot of people just follow the leader and go with whats easy rather than going with whats right....
Yeah I wish mopar had a harness for the magnum and hemi engines at a reasonable price like the chevys have.
hopefully as more engines show up in junkyards the price will come down on engines and wiring. Ron....
[Re: Mopar Ron]
#235899
05/27/13 02:55 AM
05/27/13 02:55 AM
fstfish66
levittown pa
RON there are kits to modify the mopar OD trans to shift in to OD and out automatically, it consists of a few pressure switches to do the in and out of the OD, it depends what OD trans u have a 2 wire plug or 3 wire plug,,any thing more the nthat and its computer controlled,,, ill dig around and see if i still have the web site saved,, if u e mail me and remind me,,, or do a search on it,, it has a full description and pics on the set up,, on the web pretty straight forward don fstfish66@aol.com
[Re: Mopar Ron]
#235900
05/27/13 02:59 AM
05/27/13 02:59 AM
fstfish66
levittown pa
RON i totally agree,,chevy is popular only because of pricing i believe,,they sell more then can make it cheaper,,, chevy never invented any thing,,they only copied and made it cheaper,,cause they didnt have to do the R&D,,,,follow the looser u meen,,lol monkey see monkey doo,,,,mopar in a mopar,, ford in a ford,, chevy who cares,,
[Re: Cheeto]
#235901
05/29/13 07:49 PM
05/29/13 07:49 PM
Posts: 10 California
BD79RC
California
Wish I'd seen this a year ago. I have both OBD!/OBD2 manifold/t-bodies, harnesss and pcms from a 93 and 95. the 95 has a hypertech tune. but with the Hughes cam i have in mine i'm not sure the OBD1 pcms will handle it.it's small but on a 112* lsa.
The world is not what it used to be. Family, friends and our rights and values are all that matter. The rest I leave in God's hands.
[Re: BD79RC]
#235902
06/20/13 07:03 PM
06/20/13 07:03 PM
Posts: 189 Wisconsin,USA
Bzzzz
Wisconsin,USA
what about the non viper V10 truck engines? are you doing anything for those ?
2005 Dodge 1500 Slt Hemi 2008 Chrysler PT cruiser 1984 Dodge D250 1978 Dodge D100 Adventurer 1964 Meyers Manx Dunebuggy
