Re: Won't start after distributor swap
[Re: RapidRobert]
#2359716
08/25/17 04:00 PM
08/25/17 04:00 PM
dogdays
With my CD ignitions, that's a good way to get a multitude of shocks unless you insulate your hand.
BTW, have you done my hotwire test yet? "You should be able to hotwire the ignition system. Locate the "power in" and "ground" wires. Run connections from the battery to these wires. + goes to power in, and - goes to ground. Now stsrt the engine. It should start unless it's flooded. If flooded use all appropriate steps." If it's an MSD tie the positive to both of the red wires.
R.
[Re: dogdays]
#2359777
08/25/17 05:56 PM
08/25/17 05:56 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
But at least he'll KNOW if it is working. ![devil devil](/ubbthreads/images/graemlins/custom/devil.gif)
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: 62maxwgn]
#2359883
08/25/17 09:13 PM
08/25/17 09:13 PM
amxautox
Ya, take number 1 plug out, stick your finger in the plug hole of number 1.
turn it over until number one plug hole spits on your finger.
That'll be top dead center on the compression stroke.
Then turn the crank over until the timing lines line up.
If you have already gone past, then turn it over until the lines line up for the second time, double checking with the finger in the plug hole trick.
Tom
author unknown
