Re: Recommendations for new distributor and ignition system.
[Re: 70RT Charger]
#2359466
08/25/17 02:31 AM
08/25/17 02:31 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Ive never heard of FBO but then agin I don't get out much. I'm very interested, is quality good? And the advantages? I've got their new system on my 64 Belvedere's 383. Quality is great & Don curved it for my stock 330 hp 383. Only problem seems to be that FBO's dizzy has to run off manifold vacuum & not port vacuum, so my 383 still detonates at WOT. I've called Don 3 or 4 times & he's been helpful, but said my carb is probably too lean. Carb isn't lean at all, so gotta figure it out. Really like the quality, but wish I'd gone with an Accel dizzy & MSD box.
[Re: Triggerfish]
#2359898
08/25/17 09:44 PM
08/25/17 09:44 PM
RapidRobert
Only problem seems to be that FBO's dizzy has to run off manifold vacuum & not port vacuum, so my 383 still detonates at WOT. so gotta figure it out. what is your total with the can plugged? (initial+ slots). what RPM does the mech adv max out at? Does his dist use the 2.5" OD thin flat $22 plate with the (5) pairs of rectangular slots? or is it just for OE dists? For a solution I would limit the mech adv total and or sub in a heavier spring to slow the rate. As you know it'll take some experimentation. You want to be fairly close to the (pinging) line but absolutely not over it & there is silent ping & peoples' hearing threshold varies so you need a cushion so don't crowd it too close & pinging is extremely damageing so being a bit conservative is a good plan. Holler how it goes. EDIT For a BB I would set the total (initial+slots), not with the can, to 36 for a close/good start & I am assuming you are over that now. then work with the springs. if you are less than 36 right now depending on where the springs come in at you may need more octane. I would do a cranking compression test for a baseline #.
[Re: RapidRobert]
#2360015
08/26/17 02:24 AM
08/26/17 02:24 AM
Triggerfish
Blairsden, CA
Only problem seems to be that FBO's dizzy has to run off manifold vacuum & not port vacuum, so my 383 still detonates at WOT. so gotta figure it out. what is your total with the can plugged? (initial+ slots). what RPM does the mech adv max out at? Does his dist use the 2.5" OD thin flat $22 plate with the (5) pairs of rectangular slots? or is it just for OE dists? For a solution I would limit the mech adv total and or sub in a heavier spring to slow the rate. As you know it'll take some experimentation. You want to be fairly close to the (pinging) line but absolutely not over it & there is silent ping & peoples' hearing threshold varies so you need a cushion so don't crowd it too close & pinging is extremely damageing so being a bit conservative is a good plan. Holler how it goes. Robert, thanks for the info & advice. Not to hijack this thread, but I think the detonation may have broken a ring or two since I'm getting a lot of blow by. 97k mile orig motor & had some sludge so after we did the rislone & atf clean a couple of times and some mopar combustion chamber cleaner thought we were good to go, but seems much worse now. SO, after the rebuild is done, I'll use your info. I thought about the Revenator & Firecore combo, but needed to keep the orig look.
[Re: 70RT Charger]
#2360192
08/26/17 04:23 PM
08/26/17 04:23 PM
Posts: 15,893 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Thank you everybody for the advice!!! I beleive I will go with the Revenator/Firecore kit from RT Garage. Hopefully it will work out good. Thanks again! Good choice I promise. I love mine. Tman speaks the truth. I was having starting issues when hot, those are gone now.
Facts are stubborn things.
[Re: Azzkikrcuda]
#2360386
08/26/17 11:57 PM
08/26/17 11:57 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Stock Mopar electric distributor recurved, Mopar chrome box, Mopar.25 ohm Ballast and MSD blaster 2 coil. Simple and reliable. This is what I run and it works great.
