Page 1 of 3 1 2 3
Recommendations for new distributor and ignition system. #2357851
08/21/17 10:48 PM
08/21/17 10:48 PM
eastern,Ky
70RT Charger Offline OP
eastern,Ky
Need the whole kit and caboodle for my 550+ HP 440. Thanks!
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2357859
08/21/17 11:01 PM
08/21/17 11:01 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I have run one of these Crane set ups for 12 years, on the drag stip and street, my Son has the same in his 547 valiant. We are running MSD dizzy.
http://www.ebay.com.au/itm/CRANE-CAMS-CR6000-6445-HI6-CD-IGNITION-WITH-LX92-COIL-/291146540458?hash=item43c9afa5aa:g:hUAAAMXQuTNTK9fa
1963 Plymouth Max Wedge
1971 Barracuda
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2357915
08/22/17 12:30 AM
08/22/17 12:30 AM
good used 70's OE dist, dial in the total (slots) with the FBO $22 plate, the springs, a cap with brass terminals/ribs, check rotor phasing, reduce rotor to cap terminal clearance to 0.015". reduce lower shaft axial play to .005". all this is easier than it sounds. A '75 up OE black HEI module from a junkyard. An Accell super coil, the big yellow beast or a full 12V coil such as the CFD478 at rockauto ($16.02). I cant say it would top a capacitive discharge setup but it runs flawless for me & was cheap.
Re: Recommendations for new distributor and ignition system. [Re: ozymaxwedge] #2357959
08/22/17 01:55 AM
08/22/17 01:55 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Stock Mopar electric distributor recurved, Mopar chrome box, Mopar.25 ohm Ballast and MSD blaster 2 coil. Simple and reliable.
The only Carbs I care about are under the hood!
Re: Recommendations for new distributor and ignition system. [Re: Azzkikrcuda] #2358089
08/22/17 01:17 PM
08/22/17 01:17 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
iagree
Re: Recommendations for new distributor and ignition system. [Re: TJP] #2358090
08/22/17 01:21 PM
08/22/17 01:21 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
iagree
As far the MP box keeps working without a premature fail!
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358116
08/22/17 02:31 PM
08/22/17 02:31 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Just put all the MSD stuff on it you won't be sorry.
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358124
08/22/17 02:47 PM
08/22/17 02:47 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I love the Rev-n-ator. Had it on my 410 stroker for about two months now and love it. It was recommended to me on Moparts and I'm glad I listened now. I like the ability to have a stock look too.
http://thertgarage.com/products.html
Facts are stubborn things.
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358126
08/22/17 02:51 PM
08/22/17 02:51 PM
eastern,Ky
eastern,Ky
Thanks for the replies so far. I really don't care to spend the money. I want the best of the best with reliability in mind.
Re: Recommendations for new distributor and ignition system. [Re: Dave Hall] #2358167
08/22/17 04:58 PM
08/22/17 04:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree The MSD Ready-to-Run has adjustable mechanical advance and it's one-piece...no need for additional boxes.
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358254
08/22/17 07:44 PM
08/22/17 07:44 PM
md
mopars4ever Offline
mopars4ever  Offline
md
MSD up
Re: Recommendations for new distributor and ignition system. [Re: mopars4ever] #2358305
08/22/17 09:15 PM
08/22/17 09:15 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
My biggest issue with after market systems is the availability of parts if needed quickly and the cost. twocents
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358315
08/22/17 09:40 PM
08/22/17 09:40 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
We have been running a Mopar electronic distributor and chrome box for many years in my RR with a built wedge motor. I also have run an MSD but came back to the Mopar setup as the car ran/started better with it. I just sold the MSD box on e-bagger..
Just my $0.02... wink
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358341
08/22/17 10:32 PM
08/22/17 10:32 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I converted my electronic ignition to an HEI, ran much better. If you're interested in an HEI ignition I'd check with Davis Unified Ignition (DUI), they make ready to run distributors and good HEI modules
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358403
08/23/17 12:40 AM
08/23/17 12:40 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Any magnetic or hall effect dist (or crank trigger) with advance locked out, or a 1977+ Lean Burn Dist. The MSD 6530 Programmable, Digital 6AL-2 ignition box, and a MAP sensor.
With the programmable box, you can dial in the advance curve with a laptop based on load and RPM. Easier, quicker, and more precise than messing with mechanical advance stops, springs and vacuum can adjustments.
It also has two programmable rev-limits and retard for N2O or Boost.
I haven't tried a lean burn Dist, but the choice of the two pickups may make phasing the dist easier?
Re: Recommendations for new distributor and ignition system. [Re: 451Mopar] #2358420
08/23/17 01:11 AM
08/23/17 01:11 AM
eastern,Ky
eastern,Ky
Man the choices, figured it'd be easier than this lol
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358432
08/23/17 01:40 AM
08/23/17 01:40 AM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
MSD 8546 Pro Billet dist and MSD 6AL box. Easy as pie.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358520
08/23/17 12:15 PM
08/23/17 12:15 PM
OE dist (dial in the subsystems)/HEI module (dont forget the heat sink paste)/good full 12V coil. EDIT I was worried about my Rockauto made in china furd coil stranding me but it ain't missed a beat.
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358521
08/23/17 12:18 PM
08/23/17 12:18 PM
Wait till you get into carburetion! (You'll wish you were back here).
Re: Recommendations for new distributor and ignition system. [Re: RapidRobert] #2358522
08/23/17 12:19 PM
08/23/17 12:19 PM
eastern,Ky
eastern,Ky
HEI??? Ok I've heard of HEI in Chevys.
Page 1 of 3 1 2 3
