Re: Dynoing a 408 tomorrow; guesses on hp?
[Re: gregsdart]
#2358731
08/23/17 07:53 PM
08/23/17 07:53 PM
Posts: 10,088 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Numbers are in! 504 hp at 5700, 518 TQ at 4600. 1 3/4 dyno headers. No time to test the TTIs. A big thanks to Brian Halfeger at IMM, and Brian Hanson at R&R performance. Brian at IMM picked out the cam, carb, and the basic head configuration, and supplied a lot of those parts. Brian at R&R did the EQ heads and machine work. A big thanks to Ron Quanstrom of R&R for his expertise in finding the power on the dyno!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: 451Mopar]
#2358758
08/23/17 09:04 PM
08/23/17 09:04 PM
Posts: 2,905 Pattison Texas
CSK
Pattison Texas
Well I was off on the low side by 9 HP, and 13 ft/lbs. Must be the carb spacer LOL that was my thought also HAHA.
[Re: gregsdart]
#2358840
08/23/17 11:49 PM
08/23/17 11:49 PM
Posts: 132 Kingman, Az
Scojodak
Kingman, Az
Nice Greg. I was 4 off on hp, 7 off on tq. Good, now I have an idea on my power output.
Dakota for life!
[Re: gregsdart]
#2358845
08/23/17 11:58 PM
08/23/17 11:58 PM
gregsdart
I am VERY pleased. I didn't port match the intake, but did get quench down to .039. If the Dart the motor is going in is light enough (3,100?) the car might be capable of a 10.99.
[Re: gregsdart]
#2359148
08/24/17 02:28 PM
08/24/17 02:28 PM
Posts: 4,457 Washington
madscientist
Washington
In the first post you said 1.875 headers and in the post with the dyno numbers you said 1.750 headers.
Which headers did you use?
