Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358731
08/23/17 07:53 PM
08/23/17 07:53 PM
gregsdart Offline OP
Numbers are in!
504 hp at 5700, 518 TQ at 4600.
1 3/4 dyno headers. No time to test the TTIs.
A big thanks to Brian Halfeger at IMM, and Brian Hanson at R&R performance. Brian at IMM picked out the cam, carb, and the basic head configuration, and supplied a lot of those parts. Brian at R&R did the EQ heads and machine work. A big thanks to Ron Quanstrom of R&R for his expertise in finding the power on the dyno!
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358734
08/23/17 07:59 PM
08/23/17 07:59 PM
Curve
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358749
08/23/17 08:42 PM
08/23/17 08:42 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Well I was off on the low side by 9 HP, and 13 ft/lbs.
Must be the carb spacer smile
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: 451Mopar] #2358758
08/23/17 09:04 PM
08/23/17 09:04 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
LOL that was my thought also HAHA. smile
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: pittsburghracer] #2358762
08/23/17 09:10 PM
08/23/17 09:10 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Originally Posted By pittsburghracer
Over 400 and under 651.
I was pretty close.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358826
08/23/17 11:07 PM
08/23/17 11:07 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
As long as you are happy. boogie
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358840
08/23/17 11:49 PM
08/23/17 11:49 PM
Kingman, Az
Scojodak Offline
Scojodak  Offline
Kingman, Az
Nice Greg. I was 4 off on hp, 7 off on tq. Good, now I have an idea on my power output.
Dakota for life!
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2358845
08/23/17 11:58 PM
08/23/17 11:58 PM
I am VERY pleased. I didn't port match the intake, but did get quench down to .039. If the Dart the motor is going in is light enough (3,100?) the car might be capable of a 10.99.
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2359148
08/24/17 02:28 PM
08/24/17 02:28 PM
Washington
madscientist Offline
Washington
In the first post you said 1.875 headers and in the post with the dyno numbers you said 1.750 headers.
Which headers did you use?
Re: Dynoing a 408 tomorrow; guesses on hp? [Re: gregsdart] #2359197
08/24/17 04:16 PM
08/24/17 04:16 PM
Turns out they were 1 3/4.
