Page 2 of 3 1 2 3
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358523
08/23/17 12:19 PM
08/23/17 12:19 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Originally Posted By 70RT Charger
Thanks for the replies so far. I really don't care to spend the money. I want the best of the best with reliability in mind.
On pure mopar look system and without being scared about premature failures headaches, go to R/T garage for the rev-n-nator setup.
chromed mopar box is a GREAT ignition box as far keeps working as I told, but is an adventure how much will last long.
Then there is several options already mentioned what mostly of them require some wiring mods
Re: Recommendations for new distributor and ignition system. [Re: NachoRT74] #2358525
08/23/17 12:22 PM
08/23/17 12:22 PM
eastern,Ky
70RT Charger Offline OP
eastern,Ky
On pure stock system being plug and play on your existant system and without being scared about premature failures headaches, go to R/T garage for the rev-n-nator setup.
Will any of these set ups work with fuel injection in the future if I would decide to eventually go that route?
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358526
08/23/17 12:22 PM
08/23/17 12:22 PM
Yes it is a chebby module (see eBay or our archives for pics/schematics). small/cheap/reliable/electronically efficient. You can even mount it under the dist to hide it. EDIT I dont know FI but the guys here do & will advise.
Re: Recommendations for new distributor and ignition system. [Re: RapidRobert] #2358527
08/23/17 12:23 PM
08/23/17 12:23 PM
eastern,Ky
eastern,Ky
Man the choices, figured it'd be easier than this lol
Wait till you get into carburetion! (You'll wish you were back here).
Im fighting that also lol
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358529
08/23/17 12:24 PM
08/23/17 12:24 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Sorry edited s bit the reply, being I noticed you have a 70 and originally came with points. If you still have points, then will need to add the ECU wiring so will mean the same adding any other ign system, more or less
About injection. As far I know, yes, will work. Ignitions systems are not mandatory linked to one or another ign system. If they were, then were sold as a set allong with them
Re: Recommendations for new distributor and ignition system. [Re: NachoRT74] #2358589
08/23/17 02:40 PM
08/23/17 02:40 PM
dogdays Offline
dogdays  Offline
It may sound backwards, but I suggest choosing your EFI first, even if you don't buy it yet. But given the relative cost I see a real advantage to slipping the carb altogether and moving straight into a throttle body type EFI.
So, if you choose to go carburetion for a while, you should know that there are several approaches to ignition built into the EFI units. I think it is important to choose one that can control the ignition curve. It's much easier to input data than it is to change weights and springs. At least one setup has a built in coil driver. I believe that makes an ignition box unnecessary.
Anyway, it is possible to buy stuff that is usable with both carb and EFI, and it is also possible to buy a system that is not very compatible with the EFI. That's why I suggest choosing the EFI first even if you're going to IMHO waste money on a carb.
R.
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358629
08/23/17 04:23 PM
08/23/17 04:23 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I have FiTech Fuel Injection on my 410 stroker with the Rev n ator and it starts easily, runs great.
Facts are stubborn things.
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358657
08/23/17 05:11 PM
08/23/17 05:11 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
How much easier do you want it?
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2358997
08/24/17 08:46 AM
08/24/17 08:46 AM
None
71rm23 Offline
71rm23  Offline
None
Need the whole kit and caboodle for my 550+ HP 440. Thanks!
http://www.4secondsflat.com/
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2359065
08/24/17 12:08 PM
08/24/17 12:08 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
your head must be spinning!
Re: Recommendations for new distributor and ignition system. [Re: can.al] #2359095
08/24/17 01:08 PM
08/24/17 01:08 PM
eastern,Ky
eastern,Ky
It is lol
Re: Recommendations for new distributor and ignition system. [Re: 71rm23] #2359098
08/24/17 01:10 PM
08/24/17 01:10 PM
eastern,Ky
eastern,Ky
Ive never heard of FBO but then agin I don't get out much. I'm very interested, is quality good? And the advantages?
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2359116
08/24/17 01:39 PM
08/24/17 01:39 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Long time ago FBO got a GREAT ECU box coded as A688, pretty much similar to the Mopar Chromed box on performance. I tried that too untill failed too, then I switched to Rev-N-Nator. They stopped their production because it seems Standard products who were the manufacturer of these down FBO specs moved to China and began the quality issues
After this they offered a new aluminium box coded as HR688. Some customers got this failling too and found after remove a rear cover it was an HEI Gm module hidden down this Mopar look a like box. Then a totally brand new box came out, the HRR688 which is the one being offered at this moment.
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2359122
08/24/17 01:43 PM
08/24/17 01:43 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
You left yourself open to lots of directions. laugh
Narrow it down a few different ways.
Use How will this engine be used? Drag race only, car shows only, every day its nice, long distance.
TuningHow much fine tuning are you planning on? It runs, that's good enough. Chasing the best e.t and mph. Best mpg on the cruise.
Install comfort Are you looking for a straight up plug and chug or willing to do wire tracing and custom work? If plug and chug, what's the starting point? Wired for points or wired for Chrysler ECU.
Failure Mode If it fails, how do you prefer it to go down? Don't care, I'm calling AAA or equivalent. Gonna call my Guru. Gonna rig it on the side of the road myself with a gum wrapper. Want to be able to walk in any parts store and get a replacement off the shelf. Etc...
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2359134
08/24/17 02:01 PM
08/24/17 02:01 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
My experiences with them have not been positive, I'll leave it at that twocents
Re: Recommendations for new distributor and ignition system. [Re: Mattax] #2359135
08/24/17 02:03 PM
08/24/17 02:03 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Great Questions bow beer
Re: Recommendations for new distributor and ignition system. [Re: TJP] #2359139
08/24/17 02:06 PM
08/24/17 02:06 PM
^^^ absolutely, I totally agree
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2359151
08/24/17 02:35 PM
08/24/17 02:35 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
One more agreed
Re: Recommendations for new distributor and ignition system. [Re: 70RT Charger] #2359184
08/24/17 03:43 PM
08/24/17 03:43 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
It is lol
Because there is more than one good system out there. That's a good thing. Would you rather have no replies?
Re: Recommendations for new distributor and ignition system. [Re: Mattax] #2359207
08/24/17 04:31 PM
08/24/17 04:31 PM
eastern,Ky
eastern,Ky
Going to be all of the above except for the racer. May take it to the track and see what it runs. I would like to have one that has a rev limiter incase I miss a gear with the six speed. Was thinking of going with the FOB or Revenator. I just read where the FOB is all made in the USA now with a 5 year warranty. Just trying to figure out which is more dependable.
Page 2 of 3 1 2 3
