Re: Recommendations for new distributor and ignition system.
[Re: 70RT Charger]
#2358523
08/23/17 12:19 PM
08/23/17 12:19 PM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
Thanks for the replies so far. I really don't care to spend the money. I want the best of the best with reliability in mind. On pure mopar look system and without being scared about premature failures headaches, go to R/T garage for the rev-n-nator setup. chromed mopar box is a GREAT ignition box as far keeps working as I told, but is an adventure how much will last long. Then there is several options already mentioned what mostly of them require some wiring mods
[Re: NachoRT74]
#2358525
08/23/17 12:22 PM
08/23/17 12:22 PM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
Thanks for the replies so far. I really don't care to spend the money. I want the best of the best with reliability in mind. On pure stock system being plug and play on your existant system and without being scared about premature failures headaches, go to R/T garage for the rev-n-nator setup. chromed mopar box is a GREAT ignition box as far keeps working as I told, but is an adventure how much will last long. Then there is several options already mentioned what mostly of them require some wiring mods Will any of these set ups work with fuel injection in the future if I would decide to eventually go that route?
[Re: 70RT Charger]
#2358526
08/23/17 12:22 PM
08/23/17 12:22 PM
RapidRobert
Yes it is a chebby module (see eBay or our archives for pics/schematics). small/cheap/reliable/electronically efficient. You can even mount it under the dist to hide it. EDIT I dont know FI but the guys here do & will advise.
[Re: RapidRobert]
#2358527
08/23/17 12:23 PM
08/23/17 12:23 PM
70RT Charger
eastern,Ky
Man the choices, figured it'd be easier than this lol Wait till you get into carburetion! (You'll wish you were back here). Im fighting that also lol
[Re: 70RT Charger]
#2358529
08/23/17 12:24 PM
08/23/17 12:24 PM
NachoRT74
Valencia, España
Sorry edited s bit the reply, being I noticed you have a 70 and originally came with points. If you still have points, then will need to add the ECU wiring so will mean the same adding any other ign system, more or less
About injection. As far I know, yes, will work. Ignitions systems are not mandatory linked to one or another ign system. If they were, then were sold as a set allong with them
[Re: 70RT Charger]
#2358629
08/23/17 04:23 PM
08/23/17 04:23 PM
Posts: 15,960 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Thanks for the replies so far. I really don't care to spend the money. I want the best of the best with reliability in mind. On pure stock system being plug and play on your existant system and without being scared about premature failures headaches, go to R/T garage for the rev-n-nator setup. chromed mopar box is a GREAT ignition box as far keeps working as I told, but is an adventure how much will last long. Then there is several options already mentioned what mostly of them require some wiring mods Will any of these set ups work with fuel injection in the future if I would decide to eventually go that route? I have FiTech Fuel Injection on my 410 stroker with the Rev n ator and it starts easily, runs great.
Facts are stubborn things.
[Re: can.al]
#2359095
08/24/17 01:08 PM
08/24/17 01:08 PM
70RT Charger
eastern,Ky
your head must be spinning!
It is lol
[Re: 70RT Charger]
#2359116
08/24/17 01:39 PM
08/24/17 01:39 PM
NachoRT74
Valencia, España
Long time ago FBO got a GREAT ECU box coded as A688, pretty much similar to the Mopar Chromed box on performance. I tried that too untill failed too, then I switched to Rev-N-Nator. They stopped their production because it seems Standard products who were the manufacturer of these down FBO specs moved to China and began the quality issues
After this they offered a new aluminium box coded as HR688. Some customers got this failling too and found after remove a rear cover it was an HEI Gm module hidden down this Mopar look a like box. Then a totally brand new box came out, the HRR688 which is the one being offered at this moment.
[Re: 70RT Charger]
#2359122
08/24/17 01:43 PM
08/24/17 01:43 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
You left yourself open to lots of directions. Narrow it down a few different ways. Use How will this engine be used? Drag race only, car shows only, every day its nice, long distance. TuningHow much fine tuning are you planning on? It runs, that's good enough. Chasing the best e.t and mph. Best mpg on the cruise. Install comfort Are you looking for a straight up plug and chug or willing to do wire tracing and custom work? If plug and chug, what's the starting point? Wired for points or wired for Chrysler ECU. Failure Mode If it fails, how do you prefer it to go down? Don't care, I'm calling AAA or equivalent. Gonna call my Guru. Gonna rig it on the side of the road myself with a gum wrapper. Want to be able to walk in any parts store and get a replacement off the shelf. Etc...
[Re: Mattax]
#2359135
08/24/17 02:03 PM
08/24/17 02:03 PM
Posts: 15,567 Omaha Ne
TJP
Omaha Ne
You left yourself open to lots of directions. Narrow it down a few different ways. Use How will this engine be used? Drag race only, car shows only, every day its nice, long distance. TuningHow much fine tuning are you planning on? It runs, that's good enough. Chasing the best e.t and mph. Best mpg on the cruise. Install comfort Are you looking for a straight up plug and chug or willing to do wire tracing and custom work? If plug and chug, what's the starting point? Wired for points or wired for Chrysler ECU. Failure Mode If it fails, how do you prefer it to go down? Don't care, I'm calling AAA or equivalent. Gonna call my Guru. Gonna rig it on the side of the road myself with a gum wrapper. Want to be able to walk in any parts store and get a replacement off the shelf. Etc... Great Questions ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: TJP]
#2359139
08/24/17 02:06 PM
08/24/17 02:06 PM
RapidRobert
^^^ absolutely, I totally agree
[Re: 70RT Charger]
#2359184
08/24/17 03:43 PM
08/24/17 03:43 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
It is lol Because there is more than one good system out there. That's a good thing. Would you rather have no replies?
[Re: Mattax]
#2359207
08/24/17 04:31 PM
08/24/17 04:31 PM
70RT Charger
eastern,Ky
You left yourself open to lots of directions. Narrow it down a few different ways. Use How will this engine be used? Drag race only, car shows only, every day its nice, long distance. TuningHow much fine tuning are you planning on? It runs, that's good enough. Chasing the best e.t and mph. Best mpg on the cruise. Install comfort Are you looking for a straight up plug and chug or willing to do wire tracing and custom work? If plug and chug, what's the starting point? Wired for points or wired for Chrysler ECU. Failure Mode If it fails, how do you prefer it to go down? Don't care, I'm calling AAA or equivalent. Gonna call my Guru. Gonna rig it on the side of the road myself with a gum wrapper. Want to be able to walk in any parts store and get a replacement off the shelf. Etc... Going to be all of the above except for the racer. May take it to the track and see what it runs. I would like to have one that has a rev limiter incase I miss a gear with the six speed. Was thinking of going with the FOB or Revenator. I just read where the FOB is all made in the USA now with a 5 year warranty. Just trying to figure out which is more dependable.
