Open ended Lug nuts for Crager SS wheels small bolt #2353783
08/14/17 06:11 PM
08/14/17 06:11 PM
P
Paul_Fancsali Offline OP
P
Does anyone know if 7/16 20 open ended lug nuts for crager wheels for small bolt mopar ? I have wanted to go to long studs and I cannot located them period Jeg summitt even Crager. I need the 0.592 width If anyone has anything that will fit or even a part # Thanks
Re: Open ended Lug nuts for Crager SS wheels small bolt [Re: Paul_Fancsali] #2353785
08/14/17 06:15 PM
08/14/17 06:15 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
See if you can find a catalog for Gorilla on-line. They had a pretty good selection of 11/16 threads and IIRC that included open top.
I bought through a local shop about 10 years ago. They were tied into Keystone automotive warehouse network.
Re: Open ended Lug nuts for Crager SS wheels small bolt [Re: Mattax] #2354723
08/16/17 11:01 AM
08/16/17 11:01 AM
moparx Online content
moparx  Online Content
there is also a guy on ebag called "lugnutking" [or something close to that] who has just about any lugnut ever made for every wheel brand. the prices are reasonable too. you may want to check him out.
beer
Re: Open ended Lug nuts for Crager SS wheels small bolt [Re: moparx] #2354856
08/16/17 02:02 PM
08/16/17 02:02 PM
P
P
I will do that I have just about exhausted everyone else
Re: Open ended Lug nuts for Crager SS wheels small bolt [Re: Paul_Fancsali] #2354969
08/16/17 05:29 PM
08/16/17 05:29 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Nope, they are unobtainium. frown I took some of the special lug nuts that come with the small bolt Cragars and machined the end off of them, that is the only way except carving out your own. twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: Open ended Lug nuts for Crager SS wheels small bolt [Re: Paul_Fancsali] #2354989
08/16/17 06:14 PM
08/16/17 06:14 PM
P
P
Thanks to all yes they are not made period /i guess i will have to make my own
Re: Open ended Lug nuts for Crager SS wheels small bolt [Re: Paul_Fancsali] #2356871
08/19/17 11:42 PM
08/19/17 11:42 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
That's a bummer. Nothing wrong with machining the top cap off if needed.
Shank diameter for mag style can be an issue with replacements on some older rims. I have two sets of SBP cast slots and the lug nuts do not interchange.
Re: Open ended Lug nuts for Crager SS wheels small bolt [Re: Mattax] #2357052
08/20/17 12:18 PM
08/20/17 12:18 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Not to high jack, but I'm glad I read this.
I have two different pairs of 14 inch slots and the lug nuts I have only fit one pair. Is there a source for the larger hole wheels?
I have mechanical Aptitude.
I can screw up anything.
Re: Open ended Lug nuts for Crager SS wheels small bolt [Re: Paul_Fancsali] #2357184
08/20/17 05:12 PM
08/20/17 05:12 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Rhinodart that is what I almost did with the Super Trick nuts I used on my Challenger. Got tired of NHRA wanting me to pull a Front nut to check the studs so I searched years ago and come up with the open end lug nuts and washers and changed to long studs. Nothing wrong with the studs I was using with a closed nut, all passed tech at the drag strip but got tired of pulling a nut in 90 degree weather just to show the Tech people I was legal. Funny how they never wanted me to pull the nuts on the back rims that are Crager SS steel rims with closed nuts.
1971 HEMI E BODY REGISTRY
Re: Open ended Lug nuts for Crager SS wheels small bolt [Re: Paul_Fancsali] #2357823
08/21/17 10:01 PM
08/21/17 10:01 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I went through this years back when I put long studs in so ended up chucking the ones I had up in a lathe and drilling them with the proper bit then chasing a tap through, was hoping they didnt rust and look like crap but they held up very well
