Strut rod's don't have a press-pin hole
#2357383
08/21/17 01:12 AM
08/21/17 01:12 AM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
We noticed yesterday there is no hole in either of my strut rod's. Chrysler put a press-pin in those from the factory. Is it possible to drill a hole in those while on the car? Or are they hardened and would break many drillbits. thanks.
Still looking for LM29H1B415501, '71 Demon 340
Re: Torsion bars don't have a press-pin hole
[Re: stumpy]
#2357393
08/21/17 01:31 AM
08/21/17 01:31 AM
PAULS_340
Motown, Mi
Thanks burdar for reminding me they are strut rods...it's late and I should just quit for the day.
[Re: PAULS_340]
#2357517
08/21/17 12:00 PM
08/21/17 12:00 PM
Posts: 3,087 Michigan
A727Tflite
Your original post WAS for strut rods - someone changed it to Torsion bar. If the nut were to start backing off the car would pull badly to the side with the loose nut. The strut rod controls toe out throughout the range of lower control arm travel. As for drilling it - that shouldn't be a problem if you are thinking of drilling it.
Re: Strut rod's don't have a press-pin hole
[Re: PAULS_340]
#2357590
08/21/17 02:38 PM
08/21/17 02:38 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Your original post WAS for strut rods - someone changed it to Torsion bar. His original post said "torsion bar". He changed it to "strut rod" after Stumpy and I questioned it. Didn't the factory stop using the roll pin around 70? My 73 uses a locking nut AND a roll pin. The pin isn't even close to the lock nut once installed.
[Re: burdar]
#2357608
08/21/17 02:54 PM
08/21/17 02:54 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Has anybody ever seen a strut rod nut back off enough to get anywhere near the pin? I always thought the pin was silly.
[Re: elmor353]
#2357921
08/22/17 12:44 AM
08/22/17 12:44 AM
PAULS_340
Motown, Mi
So my driver side Strut bar nut did work its way almost off last year. A little thread lock and it's fine now. I noticed this weekend several Abody's with the pin. Good drilling project this winter when/if I pull the engine. Thanks
[Re: PAULS_340]
#2358015
08/22/17 09:35 AM
08/22/17 09:35 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
IIRC my 65 didnt have pins.Replaced them like 15 or so years ago with RMS ones with heims.No more problems with bushings etc.Rocky
Chrysler Firepower
