Re: Bent axles...wobbly wheels
[Re: an8sec70cuda]
#2356683
08/19/17 06:02 PM
08/19/17 06:02 PM
Posts: 8,082 Tulsa OK
Bad340fish
Tulsa OK
Its a 1000+ HP car with god knows how much torqueon the nitrous in a 3800b car on drag radials. I would say a 40 wouldn't be overkill.
68 Barracuda Formula S 340
[Re: an8sec70cuda]
#2356800
08/19/17 09:08 PM
08/19/17 09:08 PM
Posts: 43,744 Bend,OR USA
Cab_Burge
I can not imagine how you bend a stock 30 spline axle, let alone a 35 spline axle I have broke several stock 8 3/4 axles racing them, they had twisted 1 to 2 full axle splines on the left axle before breaking I replace them now when they have one full spline misaligned I put Strange 35 spline race axles in my old street Duster, never had a problem with them in the 8 3/4, they where dead straight even after I bent the crap out of the 8 3/4 housing and swapped them into a narrowed Dana 60 housing
[Re: an8sec70cuda]
#2356830
08/19/17 10:08 PM
08/19/17 10:08 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I would go with 35 spline race axles and watch them. If that won't hold it's all new time, expensive....
[Re: 68shifter]
#2356844
08/19/17 10:42 PM
08/19/17 10:42 PM
Posts: 12,318 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Strange has an 1147A housing end that takes the 3.15 bearing with the normal mopar bearing ID. You will have to change brakes though, or modify what you have.
Years ago Strange and MW both told me they don't recommend pro race axles on the street. Because of the hardening process they said over time with potholes and such it's possible for the axle to fracture or even bend just outside the bearing. True. Strange does not want their race axles put in a street car. Doesn't mean they don't end up there on occasion.
[Re: @#$%&*!]
#2357471
08/21/17 10:36 AM
08/21/17 10:36 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
Some people, in an effort to have the lightest possible car, make the rear axle as narrow as possible. This requires a minimal wheel backspace and results in a lot of bending stress on the axles. It would be possible to have near zero bending stress in the axle by having the axle bearing centered in the tire tread. I usually just put the axle flange near the center of the tread and run a centered wheel. This results in a bending moment of about 2.5", which isn't much. If you're running a wide tire and small backspace wheel you'd better keep an eye on it. As far as the housing goes, the same physics apply but the distance from the suspension mounts to the axle bearing is what counts. I understand and agree w/ your post, but in this particular case, that's not an issue. My car has a factory width E body Dana 60, 15x8.5" wheels w/ 5" of backspacing, and the leaf springs are only moved over about .750" from the factory location due to offset rear shackles. While it is a wide rearend, the attachment points are close to the tire. Most likely what I'll be doing is getting a new pair of 35 spline axles and go at it again. Unless the housing itself is bent, then I'll need to regroup and make plans to get a serious 9" under the car.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#2357556
08/21/17 01:32 PM
08/21/17 01:32 PM
Posts: 4,457 Washington
madscientist
Washington
Some people, in an effort to have the lightest possible car, make the rear axle as narrow as possible. This requires a minimal wheel backspace and results in a lot of bending stress on the axles. It would be possible to have near zero bending stress in the axle by having the axle bearing centered in the tire tread. I usually just put the axle flange near the center of the tread and run a centered wheel. This results in a bending moment of about 2.5", which isn't much. If you're running a wide tire and small backspace wheel you'd better keep an eye on it. As far as the housing goes, the same physics apply but the distance from the suspension mounts to the axle bearing is what counts. I understand and agree w/ your post, but in this particular case, that's not an issue. My car has a factory width E body Dana 60, 15x8.5" wheels w/ 5" of backspacing, and the leaf springs are only moved over about .750" from the factory location due to offset rear shackles. While it is a wide rearend, the attachment points are close to the tire. Most likely what I'll be doing is getting a new pair of 35 spline axles and go at it again. Unless the housing itself is bent, then I'll need to regroup and make plans to get a serious 9" under the car. What gear ratio are you using? I used the best axle strange had. They were no comparison to the Sumers Brothers 40 spline stuff.
[Re: an8sec70cuda]
#2357596
08/21/17 02:43 PM
08/21/17 02:43 PM
an8sec70cuda
madscientist...I use a 4.10 gear w/ a 295-65 drag radial or a 29.5x10.5 slick.
Moser says they typically rate their 35 spline axles to 1000 hp. They're encouraging me to go 40 spline.
[Re: an8sec70cuda]
#2357599
08/21/17 02:45 PM
08/21/17 02:45 PM
an8sec70cuda
Here's a quick video I took of the axle wobbling the other day. https://youtu.be/u7en1p9e7iU
[Re: an8sec70cuda]
#2357623
08/21/17 03:13 PM
08/21/17 03:13 PM
Posts: 19,544 Las Vegas
Al_Alguire
Las Vegas
TO be honest I don't think that it is all that uncommon to see unfortunately. I have seen it on a number of cars in the past. I would go to a big bearing 40spline myself, If possible. Our Camaro has a Dana 60 in it with Strange axles. They have been on it since 2001 and so far are holding up well. But it is mostly a street car with occasional trips to the track on a radial.
[Re: an8sec70cuda]
#2357630
08/21/17 03:30 PM
08/21/17 03:30 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I remember Monte saying that a radial car should be built like a promod in the rear...
[Re: TRENDZ]
#2357639
08/21/17 03:42 PM
08/21/17 03:42 PM
an8sec70cuda
I remember Monte saying that a radial car should be built like a promod in the rear... Yes he did. He told me that I'd eventually bend the Dana 60 housing/tubes and when that happened, to go to a 9" setup. I'm gonna pull the axles out and take some measurements to see if the rear is bent.
[Re: an8sec70cuda]
#2357896
08/21/17 11:58 PM
08/21/17 11:58 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I remember Monte saying that a radial car should be built like a promod in the rear... Yes he did. He told me that I'd eventually bend the Dana 60 housing/tubes and when that happened, to go to a 9" setup. I'm gonna pull the axles out and take some measurements to see if the rear is bent. When you pop them out, pull the o-ring off the bearing and see if they slide in and out of the housing end easily. Or if they have to be pulled one way or the other, probably towards the front, to get them in.
