Does a 71 b body have a nut welded in the front rocker cap? #2355133
08/16/17 10:40 PM
08/16/17 10:40 PM
Willow Grove PA
71sat440 Offline OP
71sat440  Offline OP
Willow Grove PA
As a bit more of a description. There is a small "end cap" piece of metal at the front of the rocker.
My car had the passenger front rotted out, the drivers side has an odd circle in the center.
I don't know if perhaps had some rot and got welded shut, but the rocker caps I see are advertised as E body units with "Will fit B body" and they have a welded nut in the center.
Didn't know if its used on E bodies and not B's and just needs welded shut. Or if it is used on B's and Ill have to drill a hole and weld a nut there or just buy the piece from AMD since its only around $30.
Re: Does a 71 b body have a nut welded in the front rocker cap? [Re: 71sat440] #2355206
08/17/17 12:22 AM
08/17/17 12:22 AM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Not sure if the E-Bodies will work, I just fabricated my own pair and welded them in. Not really hard to make.
Re: Does a 71 b body have a nut welded in the front rocker cap? [Re: 71sat440] #2355392
08/17/17 11:53 AM
08/17/17 11:53 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Have a look at the inner fender splash shields. Is there a hole in the shield for a fastener that would attach there? My 73 Challenger and 68 Dart both have a threaded insert in that rocker cap to attach the inner fender splash shields.
Re: Does a 71 b body have a nut welded in the front rocker cap? [Re: 71sat440] #2355663
08/17/17 08:48 PM
08/17/17 08:48 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Just went out to the garage & checked my 71X the fenders have been off for 30 years,no nut/hole or anything in the front rocker end cap.
