Re: Trick Flow 240 users
[Re: dartman366]
#2353933
08/14/17 10:44 PM
08/14/17 10:44 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I think this should be the official TF 240 combo/ET thread. Build data, car combo, ET results, track you race at, etc.....
[Re: fast68plymouth]
#2353947
08/14/17 11:20 PM
08/14/17 11:20 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I was looking at them at the Nats last Saturday and I have to say they are a much cleaner casting that my Indy EZ's are. If I ever take my 493 apart I would consider selling the EZ's and get some 240's Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
#2353950
08/14/17 11:29 PM
08/14/17 11:29 PM
dartman366
Mt. Vernon, Ohio
I think you are right Dwayne, so I will start,
lo deck 512, no fill, Molnar 4.250 crank w/ 2.20 rod journals, Molnar 6.535 BB chev H beam rod's w/ .990 pins, Icon forged flat top pistons in at .005 under the deck,12.3 comp, all King bearing's, Milodon super stock lo pro 8qt pan, single static pick up to a Milodon billet oil pump,Bullit solid roller cam, Crower severe duty roller lifters, lift is .690 int/ex,duration at .050 is 271int/271ex,in at 105, ootb TF 240.s with only a check over and added Pac roller springs w/ 260# on the seat and 700#over the nose, Harlan Sharp 1.5 roller rockers, Manton series 5 pushrod's,Moroso 3 vane enhanced vac pump, TF track heat intake w/ gasket match, 1050 dominator on a 2" spacer adaptor,Hedman fenderwell headers, all MSD ignition,,,trans is a 727 with steel drum and a CRT probrake vb and all CRT sourced internal parts, has run a best of 9.89 at 133 so far in my 3150# dart in the heat at Norwalk,,,,,still more tuning to do.
[Re: dartman366]
#2354009
08/15/17 12:47 AM
08/15/17 12:47 AM
Posts: 2,141 junction city oregon
viperblue72
Thank you for sharing. Converter and gearing? And is that 3150 race weight or curb weight? Also ive yet to hear from any users other than you on either trick flow 240/270.
[Re: dartman366]
#2354053
08/15/17 01:53 AM
08/15/17 01:53 AM
Posts: 5,166 CT
GTX MATT
CT
I would like to see if someone put together the combo Trick Flow said made 620 hp. HP numbers looked optimistic, but if it makes within 30-40 HP of the numbers and curve that Trick Flow said that would still be one hell of a stock stroke street 440.
[Re: dartman366]
#2354066
08/15/17 02:45 AM
08/15/17 02:45 AM
Posts: 326 Alberta
Wookie316
Alberta
A guy who runs a Cuda at one of the tracks I race at runs a set. Not sure on his exact combo but it runs 10.40's very consistent. I'll see if I can get more info and post here. I know it's a roller cam. Just not sure on the size exactly.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
[Re: Wookie316]
#2354079
08/15/17 04:51 AM
08/15/17 04:51 AM
Posts: 608 TN
1DGEMAN
TN
What is with all the photo bucket pics that don't work?
Real Men shift for themselves
[Re: dartman366]
#2354156
08/15/17 12:07 PM
08/15/17 12:07 PM
Posts: 326 Alberta
Wookie316
Alberta
Photobucket no longer offers free 3rd party hosting for photos and people have to pay now. I for one choose not to, so any existing threads with photos linked to Photobucket do not show up anymore. Many others are choosing to do the same so lots of good threads no longer have photos to view anymore.
[Re: dartman366]
#2354231
08/15/17 02:04 PM
08/15/17 02:04 PM
Posts: 1,237 North Central, Indiana
Roughbird72
I won't get to find out until next spring, other projects taking priority and I'm sloooow. lol 67_Satellite checked a couple intake ports & one exhaust port on his bench, 319/320 @.650 -- 263 @ .650 These will be going on 463" RB with a 7.10 rod.
72 Plymouth Roadrunner 11.08@123.25
[Re: dartman366]
#2354234
08/15/17 02:11 PM
08/15/17 02:11 PM
Posts: 91 sweden
carter
sweden
512ci sitting in a bone stock E-body, 3860 with driver. This is my weekend cruiser that see a track once or twice a year. Beting on it for two summers since I built it, old school and simpel.
4.25 x 4.375. B-block TF 240 OOTB. 802-COO 10.4:1 Holley 850 DP (4781) Holley SD intake with 1" open spacer MP .528 with 1.6 rockers 6 Quarter "Hemi pan" MP Dist 18°/36° Carter mech fuel pump with 3/8" original fuel line TTI 1 7/8 headers with full 3" exhaust
T/A 10" converter flash 4400 rpm
Rear 3.91 and 9x28 slicks
Engine has plenty of vacuum for my factory PDB and sound "stock". Best ET so far is 7.29 x 94 MPH. I hope for one more day at the track so I can do some more adjustments before I change camshaft.
[Re: viperblue72]
#2354478
08/15/17 09:38 PM
08/15/17 09:38 PM
dartman366
Mt. Vernon, Ohio
Thank you for sharing. Converter and gearing? And is that 3150 race weight or curb weight? Also ive yet to hear from any users other than you on either trick flow 240/270. sorry, guess I did forget a few thing's of importance,,that is race weight, the converter is a Ultimate 8" at 5200 stall, shifting at 6600 it appears it is going across the stripe at 6800, 4.56 gear's in a dana and 14X32 Phoenix out back, I still haven't optimized my timing, jetting or shift point's yet, also have not touched the suspension from when Holt's set it up for the smallblock, like I said before these heads are ootb un touched except for different valve springs and guide check.
[Re: DblOJoe]
#2354493
08/15/17 10:14 PM
08/15/17 10:14 PM
Posts: 1,505 TN
SCATPACK 1
TN
Here's mine, 1970 Cuda weighs 3490 446 ci RB 10.5 compression Pump Gas Stock 440 steel crank Icon pistons and Scat Rods Victor Intake and old style 950hp (small venturi) 260ish solid flat tappet cam ootb 240"s with Smith bros push rods and Harland Sharp 1.5 Rockers 2" Hooker super comp headers and 3" exhaust with Magnaflow Mufflers 8" ATI converter Its ran a best of 10.42 @ 127 @ US 131 Double OO that is a really good time for such a mild build. I ssume a lot of it is in the suspension. Care to share the set up? Gear, suspension, tire/wheel size, etc... Is it a ladder bar car? thanks
Old Geezer Racing
[Re: SCATPACK 1]
#2354525
08/15/17 11:18 PM
08/15/17 11:18 PM
Posts: 528 N.W. Indiana
DblOJoe
N.W. Indiana
It is a ladder bar car. It has RMS upper arms and strut rods up front with Strange single adjustable's. Has strange double adjustable coil overs on the rear. It has 30x9 bias slicks on a 10" rim. I've tried 4.30 and 4.10 gears and it's ran the same ET. I've also had another converter in it and it changed the 60 ft but still ran 10.43.
I plan on putting some radial slicks on it and opening the headers at some point to see what I can get out of it.
I should also say both my converters are pretty loose so I believe that's the reason it wasn't affected by the gear change.
[Re: DblOJoe]
#2354761
08/16/17 11:42 AM
08/16/17 11:42 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Here's mine, 1970 Cuda weighs 3490 446 ci RB 10.5 compression Pump Gas Stock 440 steel crank Icon pistons and Scat Rods Victor Intake and old style 950hp (small venturi) 260ish solid flat tappet cam ootb 240"s with Smith bros push rods and Harland Sharp 1.5 Rockers 2" Hooker super comp headers and 3" exhaust with Magnaflow Mufflers 8" ATI converter Its ran a best of 10.42 @ 127 @ US 131 Lift? or its top secret?
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
