Re: Temerature sensor [Re: ct440rod] #2360065
08/26/17 10:38 AM
08/26/17 10:38 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
I believe all radio shacks in Ohio closed. I did find a 39 ohm at work last night so I will test gauge today.
Re: Temerature sensor [Re: ct440rod] #2360139
08/26/17 02:03 PM
08/26/17 02:03 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Be aware that the gauge response to resistance is not linear so using the 39 ohm will not tell you much about the calibration or potential circuit problems. beer
Re: Temerature sensor [Re: TJP] #2360700
08/27/17 06:17 PM
08/27/17 06:17 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
With 39 ohms the gauge came up to the cold white band. Where it goes when engine is around 175.
