Re: AR Engineering 36-1 trigger on a small block
[Re: rgreule]
#2349129
08/05/17 07:27 PM
08/05/17 07:27 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
I used a MSD crank trigger mount on the passenger side for my sensor. I was running a 36-1 wheel a friend cut out for me and I switched to Andy's wheel when he released it, nice piece!
Edit, top pic is before Andy's wheel. I need to snap a new pic because it looks all fancy down there now with the Doty pulley and billet 36-1 wheel haha.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: rgreule]
#2699253
09/20/19 02:25 PM
09/20/19 02:25 PM
Bad340fish
Tulsa OK
I can take one when I get home with it on the car. Yes that is a cherry sensor.
[Re: Bad340fish]
#2699423
09/21/19 01:19 AM
09/21/19 01:19 AM
Posts: 485 Raleigh, NC
j.mcconnell
Raleigh, NC
I used SD concepts mounted on the driver side. Had to get a bit milled off the sensor mounting surface to get the airgap correct for microsquirt.
[Re: j.mcconnell]
#2699440
09/21/19 08:36 AM
09/21/19 08:36 AM
Bad340fish
Tulsa OK
This is the best picture I could get installed. It took some doing with MSD to buy the parts for the mount. They sell the crank trigger pieces individually but the people on the phone aren't real good at knowing what is what. The blank aluminum tab came from a universal kit they used to offer and the mount is just a regular small block deal. If you go this route take a deep breath and maybe a stiff drink before you call them it was interesting. Maybe its better now that Holley owns them?
The SD concepts piece wasn't around when I did this project but it looks very nice. I have his adapter to use a Jeep Cam sensor in place of a distributor and it is very nice.
I need to remove the wheel and clean it up and paint it or have it anodized. It looked so pretty in its bare billet form but it is starting to rust a little. I think he sells them coated, this was an early one.
[Re: rgreule]
#2700671
09/25/19 07:17 AM
09/25/19 07:17 AM
Bad340fish
Tulsa OK
Thanks for the replys guys. I'm gonna check out the ad mount and the mad and see what I can find. I've never set one up before or done the research but I assume since there are people putting the sensor on either passenger or driver side that it works both ways. Where is the sensors supposed to go in relation to tdc? With my setup(Megasquirt MS3X) it doesn't matter, there is an adjustment for the sensors position in relation to TDC and the missing tooth. I am sure other systems have something similar.
