Re: 440 source heads
[Re: Wedgeman]
#2344599
07/27/17 11:11 PM
07/27/17 11:11 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I have them on my street strip 440. No problems with them. Changed the springs/locks/retainers over to Comp Cams products. Had to enlarge pushrod holes for pushrods,2 shops checked them over and found no problem with them at all.Standard Stealth heads.
[Re: Wedgeman]
#2344607
07/27/17 11:23 PM
07/27/17 11:23 PM
Posts: 2,507 Sydney,Australia
tex013
Sydney,Australia
had stock Stealths , were great . Now have CNC version - even better
Tex
New best ET 10.259@129.65 . New best MPH 130.94 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Wedgeman]
#2344615
07/27/17 11:38 PM
07/27/17 11:38 PM
Posts: 2,934 Pattison Texas
CSK
Pattison Texas
I have the super stealths, they take .650 special offset intake rocker, they need a LOT of work to make them flow 330ish CFM @ .700 lift, my car runs good, but there are much better heads out there, if I was to do it over I would get the Trick Flow 240 for my application. My car is not a max effort build, it is a street strip car, so far with traction problems, no tuning yet, 12.03 @ 116 MPH 1/4 spinning, 4100 lb with 3000 ft DA , 512 low deck small solid FT cam, .576 ,248 @ .050 9.5-1 comp.
[Re: CSK]
#2344650
07/28/17 12:39 AM
07/28/17 12:39 AM
Posts: 4,893 Wichita
GY3
Wichita
Did a low compression 440 with Stealths replacing 452's. Fun little ride until I grenaded the 440.
Took those heads, sent them off to Modern Cylinder Head for CNC port, and slipped them on a 505" stroker shortblock.
They did have new (not Source) locks and retainers installed by a local machine shop when I bought them.
Very mild hydraulic Howards roller and 3.54 gears.
Best of 11.19 @ 121mph with 60 ft. still needing work in 3,600 lbs. with driver.
4,000 street miles and tons of dragstrip passes in last two seasons.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: GY3]
#2344651
07/28/17 12:44 AM
07/28/17 12:44 AM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Flow 267 on my bench out of the box and go 300cfm easily with some loving care.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: Wedgeman]
#2344656
07/28/17 12:59 AM
07/28/17 12:59 AM
CSK
Pattison Texas
Miles away from the Edelbrock stuff !! do the Edelbrock flow what they claim ? my Super Stealth out of the box flowed the same as the stealth OTB, 267,on my bench, same as Pittsburghracer's #'s
[Re: Wedgeman]
#2344666
07/28/17 01:22 AM
07/28/17 01:22 AM
Posts: 44,131 Bend,OR USA
Cab_Burge
I have a 4.150 stroke 440 block stroker motor with a set of 440 Source CNC ported heads in my shop now that broke a exhaust valve guide bottom off and drop some of the debris into the combustion chamber NOT GOOD The same customer had another different bracket motor that he broke a exhaust valve off a new set of the non ported 440 Source heads in the water box doing a uncontrolled burn out so keep that in mind There are some people who can screw up a 5 ton wrecking ball in a sand box with no tools, other than themselves
[Re: Wedgeman]
#2344722
07/28/17 08:41 AM
07/28/17 08:41 AM
Posts: 1,137 Usa
A39Coronet
Usa
After living through 3 cracked Stealth heads within 2 years (one lasted 3 or so passes), a fabbed oil pan that didn't fit, or a fabbed timing chain cover that was 1/8" off, I avoid them for pretty much everything. You get what you pay for...better quality options out there for a lil more coin. Pay now or pay later.
Only benefit I can see using their Stealth head is they somewhat resemble a stock iron head when they're painted, at a quick glance.
[Re: Wedgeman]
#2344724
07/28/17 08:44 AM
07/28/17 08:44 AM
BradH
Anyone tried the stealth or super stealth heads from 440 Source ?
What kind of power can be made with those ?
Dan Stealths have basically the same POTENTIAL as Edelbrock Performer RPM, since they are the same ports & chamber wrapped in an OEM-style casting. It comes down to what level of work is done to them.
[Re: Wedgeman]
#2344771
07/28/17 11:09 AM
07/28/17 11:09 AM
Posts: 14,575 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
For $89 more..... I'd just get some E Street heads.
In fact...... That's exactly what I did.
For me, the Stealth head is a budget head for those who really want/need the straight plugs, and/or the OE type appearance.
Between the RPM/Stealth/Sidewinder heads, I find the Stealth has the weakest exhaust port....... And the Sidewinder is the easiest to get to 300cfm on the intake side(IMO, it has the best short turn of the 3).
The RPM/E street is American made(a plus to me), and has quite a bit more room around the intake pushrods, so 3/8" pushrods and 1.5 rockers usually fit without any clearancing.
[Re: bobby66]
#2348428
08/04/17 01:02 PM
08/04/17 01:02 PM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
Stealth head porting results from flow tech today.
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
[Re: Prochargedmopar]
#2348468
08/04/17 01:52 PM
08/04/17 01:52 PM
Posts: 1,787 Keymar, MD
DusterKid
Keymar, MD
Stealth head porting results from flow tech today. Is the the super stealth version?
#2348513
08/04/17 03:13 PM
08/04/17 03:13 PM
BradH
Stealth head porting results from flow tech today. Uhhhh... whomever owns that flow bench needs to get a set of PTS calibration plates ( http://www.flowbenchtech.com/orificeplates.html) and/or some stiffer springs to keep the valves at the specified height when flowing heads. Those low-lift #s are in the Twilight Zone. I know flow bench #s can't be compared DIRECTLY, but when they're using a common calibration standard you can expect they're going to be REASONABLY close. Larry Smith's posted #s: .100" - 120 .200" - 177 .300" - 239 ... MCH's CNC Stealth program advertised #: .100" - 75.0 .200" - 156.7 .300" - 219.8 ... The high-lift #s might be perfectly comparable. However, when I see that the low-lift #s are so far off from "normal", I feel the need say something 'cuz it brings the credibility of the whole flow test into question. Don't shoot the messenger! It is what it is...
[Re: BradH]
#2348518
08/04/17 03:26 PM
08/04/17 03:26 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Kinda why if I don't see before and after numbers I keep moving on. Same bench before and after and you compare to what you see on your bench. It takes me less than 5 minutes to check intake and exhaust calibration and I do so before every different head goes on my bench. And I'm not even selling anything, I just want to know for myself. LOL
