Re: Coroner to charger
[Re: bigblockbryan]
#2348344
08/04/17 11:11 AM
08/04/17 11:11 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
I know my english is not the best, but at least is not my mother language!
Ok, lets see, all the unybody parts but the roof are the same.
Outer shell is completelly different
So anything from the unybody can be used but still will need to work on shell parts, patching or getting full panels.
Once again... is doable? Yes.
As far you can make the most posible by yourself will save a bunch of money and could worth the try.
If you have to pay for the job, maybe is better get a better car to work on unless the Charger gets a VIN that can make worth the job.
Got it?
Unless is a challenge for you trying to build a car from two cars... but maybe is better keep the Coronet as Coronet and forget about save a rusty bucket Charger?
O course mostly sure build the Charger using THAT parts car in just $600 will be cheaper than buy unybody reproduction parts!
Pics will be helpfull to post a better opinion
[Re: bigblockbryan]
#2348358
08/04/17 11:42 AM
08/04/17 11:42 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Kinda I really want a charger I just can't see spending 10 grand on a shell and still having rust to fix I was planning on ordering all the metal from amd but then this coroner came up I started thinking it maybe just as easy to do this instead I was just curious to see if anyone else had done this or thought about doing it Rather than cutting up both cars to make one Frankenstein quilt and patch work creation, just de-skin the CORONET enough to hang any good used sheetmetal along with some AMD full qtrs and whatever associated body panels you need to convert the CORONET into a Charger, then swap the Charger VIN onto the new shell
[Re: bigblockbryan]
#2348359
08/04/17 11:46 AM
08/04/17 11:46 AM
NachoRT74
Valencia, España
That's what would be, more less.
But isn't that what you call "rebody" a car? Is that legal up there? I have known not!
[Re: DAYCLONA]
#2348361
08/04/17 11:47 AM
08/04/17 11:47 AM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
Kinda I really want a charger I just can't see spending 10 grand on a shell and still having rust to fix I was planning on ordering all the metal from amd but then this coroner came up I started thinking it maybe just as easy to do this instead I was just curious to see if anyone else had done this or thought about doing it Rather than cutting up both cars to make one Frankenstein quilt and patch work creation, just de-skin the CORONET enough to hang any good used sheetmetal along with some AMD full qtrs and whatever associated body panels you need to convert the CORONET into a Charger, then swap the Charger VIN onto the new shell That's just a little bit illegal. Swapping VIN tags can get you serious jail time.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: Centerline]
#2348446
08/04/17 02:19 PM
08/04/17 02:19 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Kinda I really want a charger I just can't see spending 10 grand on a shell and still having rust to fix I was planning on ordering all the metal from amd but then this coroner came up I started thinking it maybe just as easy to do this instead I was just curious to see if anyone else had done this or thought about doing it Rather than cutting up both cars to make one Frankenstein quilt and patch work creation, just de-skin the CORONET enough to hang any good used sheetmetal along with some AMD full qtrs and whatever associated body panels you need to convert the CORONET into a Charger, then swap the Charger VIN onto the new shell That's just a little bit illegal. Swapping VIN tags can get you serious jail time. Maybe if you were dealing in stolen cars, which the laws were intended for, not for some enthusiast restoring or creating a vehicle from a number of donors/parts that are legally owned
[Re: DAYCLONA]
#2348462
08/04/17 02:41 PM
08/04/17 02:41 PM
Posts: 214 between the coasts
4mayhemi
between the coasts
That's just a little bit illegal. Swapping VIN tags can get you serious jail time. Maybe if you were dealing in stolen cars, which the laws were intended for, not for some enthusiast restoring or creating a vehicle from a number of donors/parts that are legally owned That might be the best point you've had in the VIN saga, especially considering most of us are good people keeping cars til we die. I think it matters that at some point the car will be sold and passed off as real for big bucks, and that doesn't sit well with many of us. We're talking about 20 or 80 or 250 thousand dollars, not a $30 toaster. In the OP's case, a 70 Charger is worth saving the extra $ for AMD and doing it right, rather than a hack job. So even if his welding handiwork is perfect, what, is he going to try and use house paint he can save $1100 on?
[Re: DAYCLONA]
#2348489
08/04/17 03:25 PM
08/04/17 03:25 PM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Rather than cutting up both cars to make one Frankenstein quilt and patch work creation, just de-skin the CORONET enough to hang any good used sheetmetal along with some AMD full qtrs and whatever associated body panels you need to convert the CORONET into a Charger, then swap the Charger VIN onto the new shell Fraud, swapping VINs is fraud. Using the VIN from one car one another & then insuring car 2 with the numbers from car one is also insurance fraud.
[Re: DAYCLONA]
#2348582
08/04/17 06:51 PM
08/04/17 06:51 PM
Centerline
Texas Hill Country
Kinda I really want a charger I just can't see spending 10 grand on a shell and still having rust to fix I was planning on ordering all the metal from amd but then this coroner came up I started thinking it maybe just as easy to do this instead I was just curious to see if anyone else had done this or thought about doing it Rather than cutting up both cars to make one Frankenstein quilt and patch work creation, just de-skin the CORONET enough to hang any good used sheetmetal along with some AMD full qtrs and whatever associated body panels you need to convert the CORONET into a Charger, then swap the Charger VIN onto the new shell That's just a little bit illegal. Swapping VIN tags can get you serious jail time. Maybe if you were dealing in stolen cars, which the laws were intended for, not for some enthusiast restoring or creating a vehicle from a number of donors/parts that are legally owned The law doesn't care. You can have all the good intentions in the world but VIN swapping is illegal no matter how (or why) you do it.
[Re: flypaper]
#2348591
08/04/17 07:13 PM
08/04/17 07:13 PM
Posts: 18,160 Mass
DAYCLONA
Mass
What if you took the dash frame, cowl, roof, trunk gutters And rad support off a car and used the parts of 16 other cars to make it whole again??
Well according to Mopar goody2shoers Law, that's OK, because when sheetmetal body/frame parts are separated from the donor(s), they magically become null and void of any identification ready for transplant,even if you've reconstructed 80% of the vehicle with multiple donor cars & parts, but yet when you remove the VINs from a clean rustfree/undamaged legally owned/purchased donor vehicle somehow their essence is still ingrained on the now rolling anonymous sheetmetal hulk and somehow assigning a donor VIN is taboo? it's just a machine, a collection of parts, a vehicle's identity is define legally by it's title,...paperwork, nothing more...
[Re: DAYCLONA]
#2348595
08/04/17 07:19 PM
08/04/17 07:19 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Well according to Mopar goody2shoers Law, that's OK, because when sheetmetal body/frame parts are separated from the donor(s), they magically become null and void of any identification ready for transplant,even if you've reconstructed 80% of the vehicle with multible donor parts, but yet when you remove the VINs from a clean rustfree/undamaged donor vehicle somehow their essence is still ingrained on the rolling anonymous sheetmetal hulk and somehow assigning a donor VIN is taboo? Illegal / fraud / taboo. Number swapping is for fakers & frauds - Not for the law abiding with scruples & morals.
[Re: Alaskan_TA]
#2348609
08/04/17 07:42 PM
08/04/17 07:42 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
Well according to Mopar goody2shoers Law, that's OK, because when sheetmetal body/frame parts are separated from the donor(s), they magically become null and void of any identification ready for transplant,even if you've reconstructed 80% of the vehicle with multible donor parts, but yet when you remove the VINs from a clean rustfree/undamaged donor vehicle somehow their essence is still ingrained on the rolling anonymous sheetmetal hulk and somehow assigning a donor VIN is taboo? Illegal / fraud / taboo. Number swapping is for fakers & frauds - Not for the law abiding with scruples & morals. How is what I described illegal? No numbers were changed? Parts were replaced one or 2 at a time Not all at once.
[Re: 4mayhemi]
#2348635
08/04/17 08:23 PM
08/04/17 08:23 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Came across this, in your neck of the woods? framerails Those appear to be 71-72 B body
[Re: flypaper]
#2348937
08/05/17 01:28 PM
08/05/17 01:28 PM
Centerline
Texas Hill Country
What you suggested would not be fraud since you would not be swapping VIN numbers. Simply replacing sheet metal on an existing car is not a problem. Its when a VIN tag is removed from one car and used on another that it is illegal.... and for very good reasons. Not just for theft but also to keep people from passing off a fraudulently assembled car as an original. Like passing off a Superbird clone as a "real" Superbird by transplanting an actual Superbird VIN tag on a Roadrunner body and adding the other parts required to make it a clone. Legally a car is born with one VIN number and the ONLY authority who can change that is the state DMV..... and only for specific reasons. Usually for a custom assembled vehicle or where the tag as been lost or there has been legitimate damage that destroyed the tag. Then the DMV will assign a new VIN for the car. 18 U.S. Code § 511 - Altering or removing motor vehicle identification numbers
(a) A person who— (1) knowingly removes, obliterates, tampers with, or alters an identification number for a motor vehicle or motor vehicle part; or (2) with intent to further the theft of a motor vehicle, knowingly removes, obliterates, tampers with, or alters a decal or device affixed to a motor vehicle pursuant to the Motor Vehicle Theft Prevention Act, shall be fined under this title, imprisoned not more than 5 years, or both.
