world power systems sm. block distributor Rock Auto #2347987
08/03/17 04:36 PM
08/03/17 04:36 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
Hi Guys...been quite awhile since i posted.Just going over this distributor from Rock Auto...DST3890
The mechanical advance slots are .410 which should be about 11 x 2 degrees total mechanical for 22.This should allow 12 - 14 initial and a total of 34 - 36 right out of the box!
Has anybody checked the rate of mechanical advance the stock springs provide?
It also has some other nice features like only one roll pin position and no spring lock but a screw instead.
Re: world power systems sm. block distributor Rock Auto [Re: can.al] #2348125
08/03/17 09:41 PM
08/03/17 09:41 PM
I didn't go to their site to check it but just me I would suggest a 70's OE electronic dist & the FBO $22 plate to set the mech amt where you want it & you can dial in the initial the springs & the can & reduce lower shaft axial play, reduce rotor tip clearance & check rotor phasing
Re: world power systems sm. block distributor Rock Auto [Re: RapidRobert] #2348143
08/03/17 10:02 PM
08/03/17 10:02 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
Tx RR...i'm no stranger to curving a distributor be it weld the slots,change the springs or whatever....These springs are not factory style 2 stage and look to be fairly stiff.I was wondering if anybody has mapped the curve?
Re: world power systems sm. block distributor Rock Auto [Re: can.al] #2348146
08/03/17 10:09 PM
08/03/17 10:09 PM
I'll go there sometime & check it out.
Re: world power systems sm. block distributor Rock Auto [Re: can.al] #2355542
08/17/17 04:45 PM
08/17/17 04:45 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..finally tested the distributor.Initial was 15 and by 2000 there was about 22 degrees advance having full advance of 35 degrees around 3600 rpm. ( Initial plus mechanical )This is a very slow curve and would be very helpful if you're fighting detonation in a high compression sm block.Single stage springs are loaded initially and adding 1 weak spring should work great for
a street machine to bring advance in quicker.
no welding of slots etc.
Re: world power systems sm. block distributor Rock Auto [Re: can.al] #2355567
08/17/17 05:34 PM
08/17/17 05:34 PM
New York
rarefish Offline
rarefish  Offline
New York
At $39.79
It has a scary cheap price...
Re: world power systems sm. block distributor Rock Auto [Re: rarefish] #2355720
08/17/17 10:03 PM
08/17/17 10:03 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
i agree...but it appears to be a very nice piece! I think Rock Auto has them for about $50.
such a deal!
