Page 2 of 3 1 2 3
Re: Aluminum wedge block [Re: moparmafia] #2349400
08/06/17 12:24 PM
08/06/17 12:24 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well good thing I don't have really high power, that's a relief.
Re: Aluminum wedge block [Re: Al_Alguire] #2349624
08/06/17 06:50 PM
08/06/17 06:50 PM
Yeah, right haha
Re: Aluminum wedge block [Re: Cab_Burge] #2349764
08/06/17 10:46 PM
08/06/17 10:46 PM
birdtracker Offline
birdtracker  Offline
I will be trying out my first aluminum block soon. Birdtracker
Re: Aluminum wedge block [Re: Al_Alguire] #2349795
08/06/17 11:27 PM
08/06/17 11:27 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Last I checked not many here are chasing ever last little HP..Trust me aluminum is the way to go unless you are one of those Comp, Pro Stock or Nascar guys on here...
I guess it's time for me to research the subject a little deeper... you guys have done surprisingly well with an aluminum block... and definitely headed in the right direction... I was never one that thought N/A and aluminum blocks went together in the same subject... 100 lb lose on my car would be huge... time for me to do homework I guess.. I guess number one question would be how would the car work..being 100 lb lighter on the nose.. that will be my starting point..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Aluminum wedge block [Re: moparmafia] #2350028
08/07/17 01:20 PM
08/07/17 01:20 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Shiloh you will end up like us. Moving EVERYTHING in the car back up front. We have moved literally everything, there is nothing left on the back of the car these days. We are at 54/46 after all the work. But it is a very short wheelbase car that is EXTREMELY sensitive to weight. BUT IMO the block is well worth its weight smile Building ANY racecar as light as possible allowing the weight to be moved to where it will best help the car work is the key. We are now no longer the wheelie king of the class putting it on the bumper round after round. FWIW we laso have an aluminum block in my Stratus and Dragster, had one in the Cuda too, but they don't make big power anyway...
Birdtracker interesting FBS set up there. Be anxious to see how it works for you.
Re: Aluminum wedge block [Re: birdtracker] #2350152
08/07/17 04:17 PM
08/07/17 04:17 PM
Texas
mprhound Offline
mprhound  Offline
Texas
Have you run the fbs heads before? I have a motor going together with a set, just picked up a hogan sheet metal intake for them
Re: Aluminum wedge block [Re: WHITEDART] #2350191
08/07/17 05:14 PM
08/07/17 05:14 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
the big thing about the indy maxx aluminum block is check your header clearance at the bottom. it's wider down there and may give you some clearance issues. just a heads up.
Re: Aluminum wedge block [Re: birdtracker] #2350219
08/07/17 06:02 PM
08/07/17 06:02 PM
Ky
moparmafia Offline OP
Ky
What heads are those?
Re: Aluminum wedge block [Re: moparmafia] #2350230
08/07/17 06:23 PM
08/07/17 06:23 PM
fullmetaljacket Offline
Give the boyz at BEST Machine in Michigan a shout if you wanna find the gremlins and angels in the aluminum alloy blocks. They seem to have it all locked down and are machining a host of Indy blocks to perfection.
That being said, myself compared to anyone here on the issue of weight, I am still running an iron factory block. But then again, I'm not making as much steam as some of you guys are.
Maybe an aluminum block is in the future unless I trim enough weight off the car all together to not need the special alloy block.
Re: Aluminum wedge block [Re: moparmafia] #2350309
08/07/17 09:28 PM
08/07/17 09:28 PM
Superfreak
Superfreak
It's to bad that the compacted graphite blocks are not floating around.
Re: Aluminum wedge block [Re: ] #2350498
08/08/17 02:33 AM
08/08/17 02:33 AM
Couldn't float at their weight. LOL.
Re: Aluminum wedge block [Re: moparmafia] #2350658
08/08/17 12:42 PM
08/08/17 12:42 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Compacted graphite blocks are EXTREMELY heavy. The heaviest block I ever have picked up was the spare 99 Hemi block we had. It was a very short deck block with one side of the skirt milled away. No one likes machining them as they are hard on equipment too. FWIW my 99 Hemi ready to race, carbs to pan weighed in at 885lbs! For comparison my aluminum B1 is 525lbs
Re: Aluminum wedge block [Re: Al_Alguire] #2350773
08/08/17 03:45 PM
08/08/17 03:45 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Dang
That is like old school iron headed hemis with Nascar rods and 5 lb pistons! runaway
Re: Aluminum wedge block [Re: sasquatch] #2350896
08/08/17 07:00 PM
08/08/17 07:00 PM
birdtracker Offline
birdtracker  Offline
I just got my 472 back together so I am going to race the rest of this year. I have this 540 to get ready for next spring. I have had alot of guidance from a racer in Minnesota that is running Fred Brewers. Moparhound I am going to send you a pm. Birdtracker
Re: Aluminum wedge block [Re: moparmafia] #2351272
08/09/17 12:30 PM
08/09/17 12:30 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Must be Vern smile
Re: Aluminum wedge block [Re: Al_Alguire] #2351502
08/09/17 07:11 PM
08/09/17 07:11 PM
birdtracker Offline
birdtracker  Offline
Al: absolutely. He really opened my eyes about a few things. His car is a work of art. Birdtracker
Re: Aluminum wedge block [Re: moparmafia] #2351806
08/10/17 12:13 PM
08/10/17 12:13 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
He is a good guy and likely has more experience with them than most anyone else does for sure.
Re: Aluminum wedge block [Re: Al_Alguire] #2351885
08/10/17 02:10 PM
08/10/17 02:10 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
eek
72 Plymouth Roadrunner 11.08@123.25
Re: Aluminum wedge block [Re: Al_Alguire] #2352071
08/10/17 08:37 PM
08/10/17 08:37 PM
Al, how much HP and torque differences between the two motors?
My thinking that a lot of the fast full chassis cars needing more front weight on them like you found out wouldn't mind the extra weight of a iron block up front, maybe not confused
Re: Aluminum wedge block [Re: Al_Alguire] #2352145
08/10/17 10:36 PM
08/10/17 10:36 PM
Superfreak
Superfreak
in doing a little reading on the blocks, it was stated the blocks can be lightened a fair bit and still have a lot of strength. It also stated that the correct tooling is readily available but since milling speeds require half the rpm and half the feed speed the machining costs are probably 3 times then grey iron. OK Al.....you talked me out of it.
Page 2 of 3 1 2 3
