B engine with powerglide #2346016
07/31/17 12:28 AM
07/31/17 12:28 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Anyone here tried the big block with a glide behind ?
Seems to be a problem with the glide adapter 8 bolt holes and the crank with 6 holes..
Dan
Re: B engine with powerglide [Re: Wedgeman] #2346023
07/31/17 12:45 AM
07/31/17 12:45 AM
Cedar Rapids, IA
69Mcode440 Offline
69Mcode440  Offline
Cedar Rapids, IA
TCI sells a 6 bolt adapter.
Mike
Mike
69 440 Cuda
71 Dart drag car
70 Duster drag car Best et 9.32, 145.9 mph
2019 Ram 2500 4x4
Re: B engine with powerglide [Re: 69Mcode440] #2346041
07/31/17 01:20 AM
07/31/17 01:20 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I've used both 6 and 8 bolt adaptors on several builds with zero issues. Summit has them listed if you can't find any
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: B engine with powerglide [Re: Wedgeman] #2346067
07/31/17 03:32 AM
07/31/17 03:32 AM
I have both flex plates for either crank pattern shruggy
As already pointed out they are both available up
Re: B engine with powerglide [Re: Wedgeman] #2346096
07/31/17 09:47 AM
07/31/17 09:47 AM
toronto
6PAK70CUDA Offline
6PAK70CUDA  Offline
toronto
The adapter is the least of your worries. If you have a torquemonster and you are using a brake you better be using all aftermarket internals. Don't ask me how I know...
Re: B engine with powerglide [Re: Wedgeman] #2346099
07/31/17 10:05 AM
07/31/17 10:05 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Since I don't know the first thing about powerglides,.what are the essential parts to change for 700lbs torque engine ?
School me on this...
Dan
Re: B engine with powerglide [Re: Wedgeman] #2346107
07/31/17 10:24 AM
07/31/17 10:24 AM
Central TEXAS!!!!
sr4440 Online content
sr4440  Online Content
Central TEXAS!!!!
are you planning on using a transbrake?
Without Data, you’re just another guy with an opinion.
Re: B engine with powerglide [Re: Wedgeman] #2346141
07/31/17 11:54 AM
07/31/17 11:54 AM
PA.
"Little"John
"Little"John
PA.
Dan
Dan if you would give more details you will get way better info back. Lots of us running powerglides here so we can help you get started. 700 pounds of torque is going to need some upgrades for sure so start off telling us your plans, weight, power-adder, ect, ect, ect.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: B engine with powerglide [Re: Wedgeman] #2346197
07/31/17 01:45 PM
07/31/17 01:45 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Dan
Call ATI or look on their website. They have packages for every horsepower level and won't sell you more than you need.
http://www.atiracing.com/products/trans/pg/index.htm
2011 Drag Pak Challenger
Re: B engine with powerglide [Re: rickseeman] #2346210
07/31/17 02:23 PM
07/31/17 02:23 PM
PA.
"Little"John
"Little"John
PA.
ATI offers some nice stuff. I just bought a powerglide super case and 1.98 gear set for my black duster and a Sonnax 1.58 gear set for my small tire car. After all these years of running powerglides I finally cracked a case
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: B engine with powerglide [Re: Wedgeman] #2346219
07/31/17 02:49 PM
07/31/17 02:49 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I called RPM in Indiana for some advice on a th400 and they were very helpful.You can call or e-mail
Re: B engine with powerglide [Re: Clanton] #2346234
07/31/17 03:31 PM
07/31/17 03:31 PM
Both the highest power robber automatic trannys are the TH400 and the C6 shruggy 3 drums and 3 sets of planetary gears are used in both of those trannys scope
Re: B engine with powerglide [Re: Cab_Burge] #2346307
07/31/17 06:05 PM
07/31/17 06:05 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
OK ignore the part about the th400 my point was the help in the phone call.
Re: B engine with powerglide [Re: Wedgeman] #2346638
08/01/17 12:39 PM
08/01/17 12:39 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well had one behind a 1088hp low deck and have one now behind a 1000+hp low deck now. Never any issues with either. Build it right with the right parts and no issues. Current piece is an FTI..
