B engine with powerglide
#2346016
07/31/17 12:28 AM
07/31/17 12:28 AM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
Anyone here tried the big block with a glide behind ?
Seems to be a problem with the glide adapter 8 bolt holes and the crank with 6 holes..
Dan
Re: B engine with powerglide
[Re: Wedgeman]
#2346023
07/31/17 12:45 AM
07/31/17 12:45 AM
Posts: 89 Cedar Rapids, IA
69Mcode440
Cedar Rapids, IA
TCI sells a 6 bolt adapter.
Mike
Mike 69 440 Cuda 71 Dart drag car 70 Duster drag car Best et 9.32, 145.9 mph 2019 Ram 2500 4x4
[Re: 69Mcode440]
#2346041
07/31/17 01:20 AM
07/31/17 01:20 AM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I've used both 6 and 8 bolt adaptors on several builds with zero issues. Summit has them listed if you can't find any
[Re: Wedgeman]
#2346107
07/31/17 10:24 AM
07/31/17 10:24 AM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
are you planning on using a transbrake?
Without Data, you’re just another guy with an opinion.
[Re: Wedgeman]
#2346141
07/31/17 11:54 AM
07/31/17 11:54 AM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Since I don't know the first thing about powerglides,.what are the essential parts to change for 700lbs torque engine ?
School me on this...
Dan Dan if you would give more details you will get way better info back. Lots of us running powerglides here so we can help you get started. 700 pounds of torque is going to need some upgrades for sure so start off telling us your plans, weight, power-adder, ect, ect, ect.
[Re: rickseeman]
#2346210
07/31/17 02:23 PM
07/31/17 02:23 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
ATI offers some nice stuff. I just bought a powerglide super case and 1.98 gear set for my black duster and a Sonnax 1.58 gear set for my small tire car. After all these years of running powerglides I finally cracked a case
[Re: Wedgeman]
#2346638
08/01/17 12:39 PM
08/01/17 12:39 PM
Posts: 19,356 Las Vegas
Al_Alguire
Las Vegas
Well had one behind a 1088hp low deck and have one now behind a 1000+hp low deck now. Never any issues with either. Build it right with the right parts and no issues. Current piece is an FTI..
