73/74 Roadrunner questions #2345826
07/30/17 06:48 PM
07/30/17 06:48 PM
SINY
SanityLost Offline OP
SINY
First question is about the roof stripes, 73 have the strobe stripe and I have seen some 74's with a solid stripe over the roof is this a 74 only thing? Next question is about the rally instrument cluster bezel, what is the difference between the 71-73 bezel to the 74 bezel? And lastly the speedo, should it be a 150mph or 120 mph speedometer? And auto trans console, tShift slap stik or Ball shifter handle?
Re: 73/74 Roadrunner questions [Re: SanityLost] #2345870
07/30/17 08:23 PM
07/30/17 08:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 73/74 Roadrunner questions [Re: SanityLost] #2345893
07/30/17 09:21 PM
07/30/17 09:21 PM
SINY
SINY
Great Info THANK YOU!!!
Re: 73/74 Roadrunner questions [Re: SanityLost] #2345926
07/30/17 10:21 PM
07/30/17 10:21 PM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
I've never personally seen a 74 with the solid stripe, I think it might have been a late year thing. I've seen the ball shifter before, but the two of these cars I've owned with the slap stick both had the t handle shifter. My current 74 has a column shift, and it was an original 400 hp car. The 74 dash has the little icons next to the headlight and wiper switch, you can see them in the pics in the brochures. My current dash is out of a 73, and has a 150mph speedo. The other cars I've owned were all 120mph. So not sure what options you had to order to get those things.
Re: 73/74 Roadrunner questions [Re: SanityLost] #2346120
07/31/17 10:57 AM
07/31/17 10:57 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The solid stripe was a 74 thing, as was the little icons beside the headlight and wiper switches. Physically they interchange with 71-73. My 73 satellite parts car was built with a rallye dash with the 120mph speedo and no tach. Did the tach option get you the 150 speedo? Slapstick should be a t handle.
Re: 73/74 Roadrunner questions [Re: DaytonaTurbo] #2346243
07/31/17 03:47 PM
07/31/17 03:47 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
these were all running changes in parts that will vary in respect to date based on which assembly plant
T-handle to round knob
150 speed-o to 120 unit
introduction of switch "ICONS"
