Re: 511 project [Re: mopar dave] #2345502
07/30/17 12:05 AM
07/30/17 12:05 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
my ECP works great !!! 512cid, cold AC, 105 outside temps, 185ish all day long
Re: 511 project [Re: CSK] #2345504
07/30/17 12:09 AM
07/30/17 12:09 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Good to hear. Do you have electric or mechanical fan?
Re: 511 project [Re: mopar dave] #2345507
07/30/17 12:36 AM
07/30/17 12:36 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
18" 7 blade direct,Flex a lite
Re: 511 project [Re: CSK] #2345508
07/30/17 12:40 AM
07/30/17 12:40 AM
Mt Morris Michigan
Mt Morris Michigan
17" 6 blade. Will see.
Re: 511 project [Re: mopar dave] #2345510
07/30/17 12:46 AM
07/30/17 12:46 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
should do good
Re: 511 project [Re: mopar dave] #2345511
07/30/17 12:46 AM
07/30/17 12:46 AM
Mt Morris Michigan
Mt Morris Michigan
I primed engine again today and rolled it over with the starter a few revs to make sure all pushrods are turning being it has a flat tappet cam. I can hear a clicking sound from the starter/vert area. Not sure what it is. Looked at vert bolts and they are not hitting anything. I can hear it click once/revolution. Either vert or trans. I have the trans in neutral.
Re: 511 project [Re: mopar dave] #2345531
07/30/17 01:21 AM
07/30/17 01:21 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
things could make noise, converter not full, no load on the front pump.
Re: 511 project [Re: CSK] #2345555
07/30/17 02:36 AM
07/30/17 02:36 AM
Mt Morris Michigan
Mt Morris Michigan
Ok. Hope thats all it is. Was gonna fire it up in neutral so everything fills up,but not sure thats nessessary.
Re: 511 project [Re: mopar dave] #2345561
07/30/17 03:54 AM
07/30/17 03:54 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
yes fire it up in neutral with 5, or more qts already in it before you start it. I like to have the wheels off the ground on stands
Re: 511 project [Re: mopar dave] #2345623
07/30/17 10:42 AM
07/30/17 10:42 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Originally Posted By mopar dave
Egineered cooling products Radiator is in. Surprised how well the summit shroud fit radiator and fan. Think this will cool?
That looks real good!Soon you will be tuning on that carb and that will be fun.
Re: 511 project [Re: Clanton] #2345635
07/30/17 11:28 AM
07/30/17 11:28 AM
Mt Morris Michigan
Mt Morris Michigan
I have Doms number for that. Shouldn't be too far off. Had Dom and Mark whittier insite on dominator build.
Re: 511 project [Re: CSK] #2345636
07/30/17 11:29 AM
07/30/17 11:29 AM
Mt Morris Michigan
Mt Morris Michigan
yep, always up on stands during break in.
Re: 511 project [Re: mopar dave] #2345662
07/30/17 12:16 PM
07/30/17 12:16 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
That is great to have some tech help from builders who know how.I used a 1050 in the 1990's[n/a] with a .509 and a .590 cam and liked it.
ps:Don't take my continued post's as me being a know it all,I am just making conversation.
Re: 511 project [Re: mopar dave] #2345669
07/30/17 12:28 PM
07/30/17 12:28 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Do you have a deep trans pan?I think as long as you have 1.5 qts in the vert and about 7 in the pan the trans should be ok with the main concern being the vert being dry.
Re: 511 project [Re: Clanton] #2345716
07/30/17 02:48 PM
07/30/17 02:48 PM
Mt Morris Michigan
Mt Morris Michigan
no problem. I take all opinions and comments. Its very helpful. No professional here either. Been thru a couple trade schools and wrenchin most of my life, but stall appreciate others insite. always helpful.
I have 1 qt in the vert and 10qts in trans with deep pan. should be full.
Re: 511 project [Re: mopar dave] #2345735
07/30/17 03:11 PM
07/30/17 03:11 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Your carb must be 2" above the hood line on the front edge.For jetting I ran 88pri/92 sec no pv's so I will be interested to see what you end up with a pv in front if yoou do that.
Re: 511 project [Re: Clanton] #2345749
07/30/17 03:51 PM
07/30/17 03:51 PM
Mt Morris Michigan
Mt Morris Michigan
I'm using a six pack hood. hoping filter clears. I believe i put a 86/93 in it with a 6.5pv
Re: 511 project [Re: mopar dave] #2345763
07/30/17 04:25 PM
07/30/17 04:25 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Nice!I was able to tune good vacuum so I hope you can also.I also wanted to say I use a Tee handle on the corner valve cover studs and it makes things easy to undo.
