Page 7 of 7 1 2 3 4 5 6 7
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: Bryce Mulvey] #2343588
07/26/17 11:19 AM
07/26/17 11:19 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
you posted in the very same discussion back in the day:
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1689226/2.html
although the dude in Colorado didn't reply or update, it probably wasn't ever resolved. There were other besides Mopar guys that got the stick broke off in them. Remember reading that on the bullet.
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: Bryce Mulvey] #2343613
07/26/17 12:11 PM
07/26/17 12:11 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Plenty of unhappy people over on YB who paid and got nothing.
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: fast68plymouth] #2343942
07/26/17 10:08 PM
07/26/17 10:08 PM
Idaho
LaRoy Engines Offline
Idaho
Originally Posted By fast68plymouth
This isn't a suggestion......... more like a thought that popped in to my head.......
It would make for an interesting dyno test session...... AW220 vs BPE heads vs Hughes Big Mouth vs some decent hand ported RPM's....... All on the same 422-ish roller cammed short block.
If the thought ever came to fruition, and I was rich, I'd like to have some skin in that game. As something different, I believe my choice would be to prepare the Indy LAX iron head.
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: LaRoy Engines] #2760092
04/04/20 06:11 PM
04/04/20 06:11 PM
Australia
MisterBee Offline
MisterBee  Offline
Australia
Hi All,
For those interested, I got my Airwolf/ Bloomer combo going after a few years of gathering parts!
The engine was built by Marcus Giobbi at Bullet Race Engineering in Adelaide, South Australia. They do a lot of high-end billet stuff so in comparison to all that, my engine is a bit agricultural.
After all this time and effort, I've got to say I'm pretty happy with it, and the engine builder was really impressed with the quality of the heads and the crank.
The only real issue we had was with valvetrain geometry, and associated spring to rocker clearance, but that was fixed pretty easily.
Anyway, long story short - combo is as follows;
360 +.040
Bloomer 4.25 crank with 11.7 comp
98 Octane fuel
Air Wolf heads
Solid Roller Cam - 257 duration @ .050 .645 lift
1050 Quick Fuel 4150 Carb
Dyno'd at 625hp @ 6100 with peak 597ft/lbs of torque at 5100.
Torque was 580 from 4200
Really happy with the results and the whole process so far.
Just got to get it in a car now and get to the track!
All the best to everyone! I hope this gives you all some inspiration!
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: MisterBee] #2760617
04/06/20 04:31 AM
04/06/20 04:31 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
Good job mate,what intake are you running and pipes those boys do trick work over there,i thought she may have peaked higher in the rpm.
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: Ian] #2760936
04/06/20 10:59 PM
04/06/20 10:59 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
https://www.ebay.com/itm/184240844845?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
speedmaster 215cc CNC heads.....
Tony
70 AARCuda Vitamin C
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: 70AARcuda] #2760951
04/07/20 12:01 AM
04/07/20 12:01 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Not CNC as I understand the term.....and assembled with " their " valves and springs
https://www.jegs.com/i/Speedmaster/746/PCE281.2151/10002/-1
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: tubtar] #2760953
04/07/20 12:04 AM
04/07/20 12:04 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
For the extra 100.00 , these seem to be a bargain.
Cylinder heads
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: tubtar] #2760956
04/07/20 12:14 AM
04/07/20 12:14 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Cylinder heads
Those are the ones I link too...that did now link....
Tony
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: 70AARcuda] #2760979
04/07/20 03:24 AM
04/07/20 03:24 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Yessir.
It took me a minute to figure out a proper link for them.
The heads from Jegs are the same castings I think , but do not get nearly the attention , or they would be crowing flow numbers.
I wish I would have seen those two weeks ago , but I bought a set from Toth.
Less money , but less cylinder head too.
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: tubtar] #2761244
04/07/20 08:00 PM
04/07/20 08:00 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Not to be a negative Nelly, but those are pretty stout flow numbers for $2000. I'd like to see the flow numbers on a "known" reputable bench.
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: cudadoug] #2761361
04/08/20 06:22 AM
04/08/20 06:22 AM
Newark,De
hemi471 Offline
hemi471  Offline
Newark,De
I thought the same thing, if had to choose I would buy the new Trick Flow heads.
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: Ian] #2766968
04/21/20 11:59 PM
04/21/20 11:59 PM
Australia
MisterBee Offline
MisterBee  Offline
Australia
Hi apologies for the slow delay.
Intake is a ported M1 - Pipes were dyno pipes 1 3/4 into 3"
He's built a few SBM strokers - mostly 408s, and reckons anything with the stock port arrangement peaks at about 6400.
Re: AIRWOLF 220 Sbm heads tested on 360 [Re: cudadoug] #2767017
04/22/20 08:58 AM
04/22/20 08:58 AM
The Great White North
RAMM Offline
RAMM  Offline
Ya really, 270 @ .400" --I seriously doubt that. Missing sparkplug is usually about 30cfm. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
