Mp stroker crank #2343024
07/25/17 01:09 PM
07/25/17 01:09 PM
Spencer NY
killermopar Offline OP
Spencer NY
How are the older Mopar performance forged stroker cranks? I'm thinking about contacting a guy who has on with a set of Crower rods. I just want to make sure it's worth my time.
Re: Mp stroker crank [Re: killermopar] #2343037
07/25/17 01:43 PM
07/25/17 01:43 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Ran one for years in a 13 to 1 422 w5 motor with no issues at all. Beat on it a bunch
69 Dart GTS, performance upgrades in progress
11.26@ 118.40 best so far. Stock 360 shortblock with eddie heads.
3285 race weight
Re: Mp stroker crank [Re: killermopar] #2343243
07/25/17 08:01 PM
07/25/17 08:01 PM
Spencer NY
Spencer NY
I guess I should mention it's for a b block. I'm sure it doesn't matter.
Re: Mp stroker crank [Re: killermopar] #2343262
07/25/17 08:55 PM
07/25/17 08:55 PM
AndyF Offline
AndyF  Offline
Depends how old the kit is. I think a long time ago they were made in the US, maybe Moldex or someone like that. Then they switched to SCAT as the supplier.
The guys who ran MP for years didn't really care about quality or fit and finish so it is a crap shoot. I've never heard anything bad about the MP cranks other than the fact that they are heavy and that they use a Mopar size rod journal.
Mopar Performance refused to accept the fact that the 2.200 journal worked just fine. They continued to use the gigantic Mopar rod journal up until the very end. But if it is a complete rotating assembly and it fits in your block then it should be fine. Don't pay more than Molnar or 440Source prices though. MP used to charge a ton for the stroker cranks but they aren't worth what they charged. It isn't like they were selling Callies or Winbergs or something like that. It is most likely just a reboxed SCAT crank.
Re: Mp stroker crank [Re: killermopar] #2343276
07/25/17 09:28 PM
07/25/17 09:28 PM
Kansas Roads Between 0 and 140...
EV2Bird Offline
Don't ask. Don't tell.
EV2Bird  Offline
Ive used alot of the MP cranks, mainly because for some reason I could find them here and there alot cheaper then then most china cranks.
Never an issue.
Ebay is full of good deals (at least on small blocks) with mixed strokes like a 340 main with a 360 stroke and the likes.
Re: Mp stroker crank [Re: killermopar] #2343577
07/26/17 10:57 AM
07/26/17 10:57 AM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
Discussed in a previous thread ... 99% sure it's the same crank/rods.
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2177528/1.html
Everyone passed on it and it's still out there like a worm on a Mopar fishing hook. I'm sure the rods would be just fine but again the 2.375" journals are very 1990's. If you could get the crank and rods for ... $800, I'd go for it. Last time I looked, they dropped from $1500 to $1400 so we're not close.
For $900 you can get this crank: http://store.440source.com/Ultralight-Crankshaft/productinfo/40042506800-6-LW/ I'm doing this 440 Source crank in my next 400 block build. For $2400, you can get a whole balanced stroker kit including this crank from 440 Source.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Mp stroker crank [Re: killermopar] #2343592
07/26/17 11:41 AM
07/26/17 11:41 AM
Spencer NY
Spencer NY
That's what I needed to know. Thanks guys!!
Re: Mp stroker crank [Re: killermopar] #2343616
07/26/17 12:14 PM
07/26/17 12:14 PM
AndyF Offline
AndyF  Offline
I can understand a guy wanting to sell parts for what they paid for them, but sometimes stuff goes down in value. Typewriters aren't worth much anymore even if you paid $1000 for new one back in the 80's.
Summit off line?
by jcc. 07/18/19 08:24 PM
'83 Mercedes Paint - Clear Coat?
by Faust. 07/18/19 07:27 PM
Dual Plane Intake Porting Pics
by parksr5. 07/18/19 07:19 PM
1969 Valiant door glass channel weather strip
by coro500net. 07/18/19 06:36 PM
1961 Seneca gas tank
by coro500net. 07/18/19 06:29 PM
Mopar distributor nylon shaft collar
by Lee446. 07/18/19 05:58 PM
Moparts Recent Posts
Summit off line?
by W.I.N. racing. 07/18/19 08:28 PM
Power Valve
by 72 RR DUDE. 07/18/19 08:25 PM
mono leaf springs
by Dabee. 07/18/19 08:19 PM
Vinyl top or not?
by BloFish. 07/18/19 08:15 PM
by BSB67. 07/18/19 08:12 PM
by shinysidup. 07/18/19 08:11 PM
