Approximate Amount of Hours of Labor
#2342156
07/23/17 10:05 PM
07/23/17 10:05 PM
Posts: 265 Philadelphia, PA
GTXKARL
Philadelphia, PA
Hello. I was wondering about approximately how many hours of labour would be needed to replace the rear channel, the Dutchman panel, and the patches in the corners of a 1970 B-body? And to repaint corner panels and the roof.
“Working on cars teaches you patience... and every curse word imaginable.”
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Approximate Amount of Hours of Labor
[Re: GMP440]
#2343098
07/25/17 03:29 PM
07/25/17 03:29 PM
GTXKARL
Philadelphia, PA
I am just trying to get an idea how much this job is going to cost me. My guy wants to put the corner pieces in, the Dutchman panel, the package tray supports, and the window supports. Also, I guess the paint work. Just want to get a fair price idea. Thanks for the help.
[Re: GTXKARL]
#2343122
07/25/17 04:09 PM
07/25/17 04:09 PM
GTXKARL
Philadelphia, PA
These pictures in the updated posts are shown.
[Re: GTXKARL]
#2343141
07/25/17 04:40 PM
07/25/17 04:40 PM
Posts: 1,637 Florida
GMP440
Just saw your pics. You definetely need to fabricate a section of metal for the top of the package tray so the top of the package tray supports the bottom of that front dutchman strip. Also, get the right and left outer lower window corners. It has nice corner channels you can use. Do you know how much more rot under the paint there is? The outer areas look good. The labor rates are going to be anywhere from $90 to $110 per hour. Might be more in your area. Just looked at the Motors Repair guide. Prime and repaint for roof is 4.8 hrs. ( Does not include working out dents, etc.) Also, add time to blend the paint with the rest of the body. Rear window frame is 1.5 hrs. No labor listing for dutchman. A lot of time is taken to get everything in alignment. I fit the glass as I went along. I must have fitted it 5 times. Keep in mind; does the body man have to fabricate pieces that are not reproduced? That equals more labor time. To get a better idea of repair costs you need to have body shop give you an estimate. Did your bodyman give you a price?
[Re: GMP440]
#2344123
07/27/17 10:13 AM
07/27/17 10:13 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
The labor rates are going to be anywhere from $90 to $110 per hour. Might be more in your area. On this side of PA it's more like half that.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: GMP440]
#2344357
07/27/17 02:59 PM
07/27/17 02:59 PM
GTXKARL
Philadelphia, PA
Thank you for the help. My problem is I am still waiting for an estimate from my bodyguy for my car. I am just wondering if it would be more cost effective if I replaced the package tray. Or is the package tray a separate part from the channel? All the parts I need I can get. He wouldn't need to fabricate anything.
[Re: GTXKARL]
#2344586
07/27/17 11:48 PM
07/27/17 11:48 PM
Posts: 21,508 It's a dry heat
gtx6970
It's a dry heat
Im going to go out on a limb here. And say IF your body man actually does give you an estimate. Chances are it will be an open ended estimate. Any good metal man knows , rust spreads. Once you open it up this WILL get worst. Been there , done that Im not a body man, but Ive done enough body work to know 15 hours isn't going to be even close to fixing this. Let alone paint work included. One thing Ive learned working for myself and on old cars, the labor and time guides are useless. There's no such thing as flat rate on old cars. At least not in my world just my
[Re: GTXKARL]
#2344861
07/28/17 03:02 PM
07/28/17 03:02 PM
GTXKARL
Philadelphia, PA
I know it is not going to be a cheap repair. I was just trying to get an idea of how much it would cost and the likely hours of labor. I was wondering if it would be less than forty hours. And I was going to pay for parts. I was always told to get a start date and an expectant end date with the estimate. My bodyguy is on vacation at the moment. Thanks everyone for your help.
[Re: GTXKARL]
#2344872
07/28/17 03:19 PM
07/28/17 03:19 PM
GMP440
Definetley more than 40 hours, plus the cost of parts. Remember, a lot of labor hours is spent test fitting, trimming, grinding , smoothing. Keep in mind, this is a very intricate, precise welding project that you will be doing. Has your bodyman done these type of welding projects before? How much are you willing to spend to do this?
[Re: GMP440]
#2344891
07/28/17 03:58 PM
07/28/17 03:58 PM
gtx6970
It's a dry heat
Definetley more than 40 hours, plus the cost of parts. Remember, a lot of labor hours is spent test fitting, trimming, grinding , smoothing. Keep in mind, this is a very intricate, precise welding project that you will be doing. Has your bodyman done these type of welding projects before? How much are you willing to spend to do this? Agreed, I know I wouldn't do it for 40 hours. Throw in all kinds of compound curves on top of fitting repop parts isnt fun. If I had to make a guess. And figuring paint work in. I would say it'll be closer to 100 if not over. I'd bet money it gets worst once you get the really visible stuff out of the way. Rust repair sucks.
[Re: gtx6970]
#2345002
07/28/17 08:49 PM
07/28/17 08:49 PM
GTXKARL
Philadelphia, PA
Hi GTX6970. I don't want to sound stupid but is that for over a hundred hours on quarter panels because when my bodyguy looked at my car he seemed to think the patches would be fine. He looked from underneath the trunk. I am just trying to get an idea. And I really appreciate the information and help from you and GMP440. Thanks.
[Re: GTXKARL]
#2345030
07/28/17 10:01 PM
07/28/17 10:01 PM
gtx6970
It's a dry heat
Hi GTX6970. I don't want to sound stupid but is that for over a hundred hours on quarter panels because when my bodyguy looked at my car he seemed to think the patches would be fine. He looked from underneath the trunk. I am just trying to get an idea. And I really appreciate the information and help from you and GMP440. Thanks. No idea. I haven't kept track of labor for individual hours / areas. This car has had A LOT of sheetmetal replaced. Once Im done with it( here very soon ) I'll add up the total labor hours. If I had to put a guess on your repair. I think 40-50 is reasonable. Your talking about a lot of hand fitting. Possibly some fab work for areas/sections not avail in the aftermkt The paint work required is going to depend a lot on the type of paint on it now. If its base clear, it'll be reasonably easier to blend in. Single stage ,,,not so much
