1970 Challenger,,,
Automatic, floor console
TTI 2" headers installed,,,, ( 440/727 )
( was a 318/904 drivetrain w/stock exhaust )
Problem: bracket coming down thru floor from gear shifter is right next to the header collector,,,,AND the lower trans rod going to the gear selector is hitting big time along the side of the header,,,,
Linkage cannot be hooked up due to the clearance issues,, (minor grinding here and there will not fix the problem )
What are people doing with similar set ups ? ( 70 E body, 727, headers with stock console ) ??
I was trying to retain the stock console,,,and avoid running a aftermarket shifter,,,but not so sure it's possible ?
Is there different linkage that might work ?
Any pic's of what people are running in this situation ?
thanks for any help.....
Doug
