Re: Best Placement for O2 Bung?
[Re: JonsGottaDusta]
#234065
02/23/09 07:35 PM
02/23/09 07:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
In the collector... 3 oclock or 9 oclock so it doesnt hold water, in front of the evac (up stream) if using one but try to get it in the flow of all the tubes for the best average reading, like was said slip on collectors can cause air leaks and give a false reading
[Re: hemisurfer]
#234067
02/23/09 09:18 PM
02/23/09 09:18 PM
Posts: 6,236 san diego
JonsGottaDusta
san diego
It should be placed in your bung hole.
Funny "Best Placement for O2 Bung?"
Shoulda read the title.
I was wondering about the position, so thanks. These are 1 piece headers, and I am putting in a wideband. Thanks guys.
[Re: Bill MeLater]
#234069
02/23/09 09:28 PM
02/23/09 09:28 PM
JonsGottaDusta
san diego
Enough can't be said for stating the obvious...Three thumbs up
Are you related to "flypaper"? You sound exactly like him... +3
[Re: 70sixpkrt]
#234071
02/23/09 09:45 PM
02/23/09 09:45 PM
JonsGottaDusta
san diego
Anybody have pics? Is it best to have two(1 in each header) or will 1 be sufficient?
I was also wondering if one is good enough or not.
#234072
02/23/09 09:50 PM
02/23/09 09:50 PM
MR_P_BODY
I just run 1... cant affort 2 wide bands. I make a pass with it in 1 side then flip it to the other side for the next pass... if all is well, I pull the sensor and plug it
[Re: MR_P_BODY]
#234074
02/24/09 12:40 AM
02/24/09 12:40 AM
Posts: 160 Florida
hemisurfer
Agreed one for each side, run one side one pass then the next side. Lots of things can cause a need for jet stagger from side to side (intake/heads etc). I run mine at 9 and 3 O Clock on both sides. The car is street/strip so rather than mount it in the header I mounted it in the collector/reducer. I believe I read somewhere that the 02 sensor needs to reach a certain operating temp to work correctly, so put your bung hole as close to the collector as possible. Funny thread ...
[Re: hemisurfer]
#234075
02/24/09 12:49 AM
02/24/09 12:49 AM
MR_P_BODY
Most O2s now days have there own heaters
[Re: MR_P_BODY]
#234076
02/24/09 12:53 AM
02/24/09 12:53 AM
Posts: 160 Florida
hemisurfer
I did not know that, thats what happens when you get past 40; info over load. In that case I guess you could put your bung hole anywhere.
Chris
[Re: MR_P_BODY]
#234078
02/24/09 02:24 AM
02/24/09 02:24 AM
Posts: 43,119 Bend,OR USA
Cab_Burge
I have mine in the exhaust pipe(street car) just after the collector on the full exhaust and another set in the colletor extensions for at the track testing with open headers, no difference in readings between the two I started out with a LM1 and then bought a FAST system with the dual wide band reading, I have since bought the LC1 upgrade for the LM1 do to its data logging and transferring ability which the FAST system does not have Thank twice and avoid buying twice
[Re: aarcuda]
#234081
02/25/09 12:02 AM
02/25/09 12:02 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
i have mine in a small section of pipe at 10 oclock just after the collector/reducer
You done with that thing yet?
Don't run the O2 sensor unheated, you'll toast them quick.
