Best Placement for O2 Bung? #234062
02/23/09 06:37 PM
02/23/09 06:37 PM
san diego
JonsGottaDusta Offline OP
san diego
Hey Everyone,
I am putting an 02 Sensor on my car and was wonder where it will give me the most accurate reading? I was thinking in the header collector, but wasn't sure. Let me know.
- Jon
Re: Best Placement for O2 Bung? [Re: JonsGottaDusta] #234063
02/23/09 06:49 PM
02/23/09 06:49 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
If I'm not mistaken I think most people put them in the collector.
Re: Best Placement for O2 Bung? [Re: WILD BILL] #234064
02/23/09 07:27 PM
02/23/09 07:27 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
If the headers are not multiple piece, or slip on collector put it in the collector, just not in the 6 o'clock position. Any air that leaks in at slip joints will throw your reading way off, so if it's pieces put it in the lower part of a solid tube. and use that one cylinder as a guide. One piece headers are best for collector installs.
Re: Best Placement for O2 Bung? [Re: JonsGottaDusta] #234065
02/23/09 07:35 PM
02/23/09 07:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In the collector... 3 oclock or 9 oclock so it doesnt
hold water, in front of the evac (up stream) if using
one but try to get it in the flow of all the tubes
for the best average reading, like was said slip on
collectors can cause air leaks and give a false reading
Re: Best Placement for O2 Bung? [Re: JonsGottaDusta] #234066
02/23/09 07:44 PM
02/23/09 07:44 PM
hemisurfer Offline
hemisurfer  Offline
It should be placed in your bung hole.
Chris
Re: Best Placement for O2 Bung? [Re: hemisurfer] #234067
02/23/09 09:18 PM
02/23/09 09:18 PM
san diego
san diego
Funny "Best Placement for O2 Bung?"
Shoulda read the title.
I was wondering about the position, so thanks. These are 1 piece headers, and I am putting in a wideband. Thanks guys.
Re: Best Placement for O2 Bung? [Re: hemisurfer] #234068
02/23/09 09:23 PM
02/23/09 09:23 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Enough can't be said for stating the obvious...Three thumbs up
Re: Best Placement for O2 Bung? [Re: Bill MeLater] #234069
02/23/09 09:28 PM
02/23/09 09:28 PM
san diego
san diego
Are you related to "flypaper"? You sound exactly like him... +3
Re: Best Placement for O2 Bung? [Re: JonsGottaDusta] #234070
02/23/09 09:32 PM
02/23/09 09:32 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Anybody have pics? Is it best to have two(1 in each header) or will 1 be sufficient?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Best Placement for O2 Bung? [Re: 70sixpkrt] #234071
02/23/09 09:45 PM
02/23/09 09:45 PM
san diego
san diego
I was also wondering if one is good enough or not.
Re: Best Placement for O2 Bung? [Re: JonsGottaDusta] #234072
02/23/09 09:50 PM
02/23/09 09:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just run 1... cant affort 2 wide bands. I make a
pass with it in 1 side then flip it to the other side
for the next pass... if all is well, I pull the sensor
and plug it
Re: Best Placement for O2 Bung? [Re: JonsGottaDusta] #234073
02/23/09 09:50 PM
02/23/09 09:50 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
You have to look close, but you can see both mine near the tranny pan.
Re: Best Placement for O2 Bung? [Re: MR_P_BODY] #234074
02/24/09 12:40 AM
02/24/09 12:40 AM
hemisurfer Offline
hemisurfer  Offline
Agreed one for each side, run one side one pass then the next side. Lots of things can cause a need for jet stagger from side to side (intake/heads etc). I run mine at 9 and 3 O Clock on both sides. The car is street/strip so rather than mount it in the header I mounted it in the collector/reducer. I believe I read somewhere that the 02 sensor needs to reach a certain operating temp to work correctly, so put your bung hole as close to the collector as possible. Funny thread ...
Re: Best Placement for O2 Bung? [Re: hemisurfer] #234075
02/24/09 12:49 AM
02/24/09 12:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Most O2s now days have there own heaters
Re: Best Placement for O2 Bung? [Re: MR_P_BODY] #234076
02/24/09 12:53 AM
02/24/09 12:53 AM
hemisurfer Offline
hemisurfer  Offline
I did not know that, thats what happens when you get past 40; info over load. In that case I guess you could put your bung hole anywhere.
Chris
Re: Best Placement for O2 Bung? [Re: hemisurfer] #234077
02/24/09 01:08 AM
02/24/09 01:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If you look at how many wires it has, 4 or more wires
was a heater(the old single wire O2 didnt have a heater)
Re: Best Placement for O2 Bung? [Re: MR_P_BODY] #234078
02/24/09 02:24 AM
02/24/09 02:24 AM
Cab_Burge Online work
Cab_Burge  Online Work
I have mine in the exhaust pipe(street car) just after the collector on the full exhaust and another set in the colletor extensions for at the track testing with open headers, no difference in readings between the two I started out with a LM1 and then bought a FAST system with the dual wide band reading, I have since bought the LC1 upgrade for the LM1 do to its data logging and transferring ability which the FAST system does not have Thank twice and avoid buying twice
Re: Best Placement for O2 Bung? [Re: Cab_Burge] #234079
02/24/09 11:14 PM
02/24/09 11:14 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Here's where I have mine. Yes they are multi piece headers and slip on collectors and turndowns (where the bung is now)
I want your opions on where it SHOULD be please. Thanks, Don
Re: Best Placement for O2 Bung? [Re: cudadon] #234080
02/24/09 11:25 PM
02/24/09 11:25 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i have mine in a small section of pipe at 10 oclock just after the collector/reducer
Re: Best Placement for O2 Bung? [Re: aarcuda] #234081
02/25/09 12:02 AM
02/25/09 12:02 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
You done with that thing yet?
Don't run the O2 sensor unheated, you'll toast them quick.
