Re: AIRWOLF 220 Sbm heads tested on 360
[Re: J_BODY]
#1373192
09/04/13 11:30 PM
09/04/13 11:30 PM
Posts: 33 Louisiana
Bignick
Louisiana
What is Dr J's facebook page called? Can't find it.
70 Duster 422"eddy head smallblock, PTC built 904, PTC 8" conveter, Dana 60 4.56 gear
[Re: rolling 340]
#1373195
09/05/13 10:05 PM
09/05/13 10:05 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
The Wife called and said a Dr. J's box arrived on Tuesday, but I'm already in OK, getting ready for Drag Week. Thanks for the effort, and kind words J-body, even if I'm not in "the Club"!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1373196
09/05/13 10:40 PM
09/05/13 10:40 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Billy, Enjoy Drag Week. We'll need to get together at the track one of these days. It's been a while . matt
[img] [/img]
[Re: clonestocker]
#1373197
09/05/13 10:46 PM
09/05/13 10:46 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
What I am itching to know is if these heads will support an honest 650 ponies with a good non exotic roller cam shortblock under them 400+ inch 4 inch motor... If so If not.....
[Re: Triple Threat]
#1373199
09/06/13 08:23 PM
09/06/13 08:23 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My offer still stands for a FREE flow test. Then we will know how they stack up against Edelbrocks or Indy's
[Re: Triple Threat]
#1373200
09/06/13 09:43 PM
09/06/13 09:43 PM
Posts: 11,689 W. Kentucky
justinp61
W. Kentucky
If not.....
I wonder this as well. Hopefully some of these guys buying them up will share numbers with us when the motors are together. My current 59* motor makes about 625, but its bigger and fancier than most.
Dustin What is you car running now, 1/8 & 1/4?
[Re: Bryce Mulvey]
#2340496
07/20/17 07:12 PM
07/20/17 07:12 PM
Posts: 89 Australia
MisterBee
Australia
Hi All,
Its been a while, and probably a moot point now because so much time has passed. However, I finally got to take my AIRWOLF 220 heads to a reputable head/ engine shop in the last couple of weeks (yes 4 years later...I know)
The shop were initially skeptical of the advertised numbers but were impressed with the results and the quality of the heads generally...here are the results;
Lift .100 .200 .300 .400 .500 .600 .700 .800 .900 Cyl 1 Int Corr. CFM 61.7 137.9 203.2 256.0 290.8 297.8 304.4 309.1 312.6 Cyl 1 Exh Corr. CFM 58.4 110.0 147.3 175.5 194.4 209.6 218.8 221.8 222.4
I'll try and show you the full sheet once I work out how to load it (PDF).
[Re: Bryce Mulvey]
#2340497
07/20/17 07:16 PM
07/20/17 07:16 PM
B3422W5
Portage,michigan
Very impressive at 1/2 inch
