440 water pump impeller question #2340182
07/20/17 09:18 AM
07/20/17 09:18 AM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
I've got a Milodon 440 water pump with the cavitation plate "loose" on the impeller. The plate is not tight on the rivets that hold it on the blades. And it rattles when turned freehand. Still usable or not? Just a question.
Re: 440 water pump impeller question [Re: Jeff_383] #2340203
07/20/17 09:58 AM
07/20/17 09:58 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Fix it, use it
Don't be the exception.
Re: 440 water pump impeller question [Re: Jeff_383] #2340301
07/20/17 01:06 PM
07/20/17 01:06 PM
Likely it will continue to get looser & clearances might be taken up & something will hit & efficiency is being lost as is. Yes I would weld it
Re: 440 water pump impeller question [Re: RapidRobert] #2340349
07/20/17 02:25 PM
07/20/17 02:25 PM
iagree up
When in doubt do the safe thing, don't run it until you like it work grin
