Subframe Connectors - Great Investment?
#2340063
07/19/17 11:34 PM
07/19/17 11:34 PM
Posts: 1,566 Macomb, MI
vinnyd76
Macomb, MI
I'm working on a 70 A-Body that I'm considering installing subframe connectors. I would like to obtain some input from my extended family. The motor will be a 340 stroker (727 and 3.91 gear) that may see a few runs at various Mopar events throughout the season (maybe 5-months, if were lucky in the mid-west). The subframe connectors that I'm considering are manufactured by US Car Tool. Thoughts?
Thanks Vinny
Re: Subframe Connectors - Great Investment?
[Re: vinnyd76]
#2340076
07/19/17 11:44 PM
07/19/17 11:44 PM
Challenger 1
Cincinnati, Ohio
Thanks Vinny They make a huge difference for the good. Mine are the old 1.5"x2 or 3" wide tubing from direct connection connectors on my 71 E body. They were quick and easy to install especially since I had my car turned sideways on a rotisserie. The ones your wanting to install are by far the toughest to install and requires tons more welding. Are they better than the ones I used? Probably, but are they worth the extra hassle installing them? I don't know since mine made a night and day difference. My 74 does not have them and you can tell. The 71 is pleasure to drive because it handles great, way better than my 74 without frame connectors. I welded mine in one night in about an hour and was done. That will never happen with the ones you are thinking about using. Yes put some kind of connector in there.
[Re: TJP]
#2340110
07/20/17 12:57 AM
07/20/17 12:57 AM
RapidRobert
no before/after cuz it was the stock car but as said everyone has said from day 1 that it is highly beneficial/definitely recommended. Way back a chassis guy said that bolt in types that are then welded in is the best.
[Re: vinnyd76]
#2340212
07/20/17 10:35 AM
07/20/17 10:35 AM
Posts: 6,100 Valencia, España
NachoRT74
Valencia, España
I have learnt recently that SFC are sometimes unnecesary on street cars which maybe can see track couple of times a year, where the torque boxes are enough, even to hold the convertible setup. SFC are more to cars which consistently see the tracks.
But to each own
[Re: hemirdrnnr]
#2340229
07/20/17 11:34 AM
07/20/17 11:34 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
I used the U S Car Tool frame connectors on my 1967 Belvedere and they worked great Same here, for a Duster I built, if the car is undercoated it's a pain cleaning the contact points for welding and I had to add a little extra clearance for the emergency brake cable, minor trimming and a floor jack to hold them in place while welding, came out great. Key point: don't weld them in with the interior installed or...
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: vinnyd76]
#2340253
07/20/17 12:06 PM
07/20/17 12:06 PM
Posts: 4,461 Michigan
MarkZ
Worthy
Worthy
I paid a local guy who builds drag cars to install a set into my Fifth Avenue. Just used 1.5" x 3" box tube he picked up at a steel supply. Cost was $350 when all was said and done. One of the best cost to benefit upgrades I've ever done. The only reason I could see not to do it would be if you were worried about the originality of the car.
[Re: vinnyd76]
#2340273
07/20/17 12:38 PM
07/20/17 12:38 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
The bolt on style of subframe connectors that are reference, I'm assuming additional holes must be drilled in the underbody subframe? yes, additional holes must be drilled. you can find installation instructions by search for Mopar frame connector instructions to see how easy they are. i'm planning to go this route and once installed have them welded in. i want to make sure, by doing them myself, that i don't have issues with opening and closing doors. i thought about the US ones but after the 'incident' with them and having to remove the carpet i decided to go this route.
[Re: vinnyd76]
#2340298
07/20/17 01:03 PM
07/20/17 01:03 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
Made my own using 2x3 tubing. Total cost was just over $20. Cut open the rear subframe and they slid right in and made for a very strong weld. I welded the front to the torsion bar crossmember. They protrude through the rear floor area about an inch and a half but with carpet you'll hardly notice them. They add an unbelievable amount of rigidity to the body. Before these were installed... if I jacked the body up behind the front wheels the doors would become misaligned and wouldn't open or close properly. In other words the body flexed quite a bit. Now I can jack it up anywhere and there is no movement of the body at all. As a note... I welded in the subframe connectors with the doors on and closed to insure things were as straight as possible. Well worth the effort. The final product from the underside... gives the car basically a full frame.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
