Gas mileage/effeciencey 426 HEMI
#2338061
07/16/17 10:50 PM
07/16/17 10:50 PM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
I drive my HEMI convertible, all I can. I am often asked, what is the gas mileage? If you drive a HEMI convertible to a car show and take the hardware home, who cares? But after 5 years and 6,000 miles, I thought I would check it. Now I know how to produce good mileage numbers, but real world? I filled up just before the entrance ramp on I-75 and drove 74 miles just as I would my company truck, 70-80mph depending on traffic. The car is a 66' Coronet convertible with a 540" HEMI, two 750 Hollys on a Marine intake, 4175lb empty, (add 400lb. for two passengers, 3.54 gear, 250+ 11" torque converter and Gear Vendors overdrive. The tack stayed at a steady 2,200-2,500 rpm. If I got behind a truck, I passed it! We had many horn blows, and thumbs up as we made the trip. We came off the interstate and filled up at the same pump, 12.9 mpg. 4.5" stroke, Mopar Performance heads, 10.78 compression, .248/.254@ .050 cam on 112 l/c cam
Re: Gas mileage/effeciencey 426 HEMI
[Re: Hemi ragtop]
#2338132
07/17/17 12:40 AM
07/17/17 12:40 AM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
I was able to tune my EFI 572 HEMI with 3.54 gears to yield 14 MPG in my 1964 4000 pound Dodge with no compromise in drivability. That would be hard to do with a carb and normal ignition since I not only leaned out the cruise area but I also emulated vacuum advance with the timing. Never opened the hood.
[Re: Dragula]
#2338189
07/17/17 05:47 AM
07/17/17 05:47 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Your lucky, my 605 gets around 6.5 with one big carb. Jesus... thats not a carb, thats a toilet with a 1" fuel line attached...
[Re: Mopar_Rich]
#2338200
07/17/17 08:01 AM
07/17/17 08:01 AM
Hemi ragtop
Tennessee
I was able to tune my EFI 572 HEMI with 3.54 gears to yield 14 MPG in my 1964 4000 pound Dodge with no compromise in drivability. That would be hard to do with a carb and normal ignition since I not only leaned out the cruise area but I also emulated vacuum advance with the timing. Never opened the hood. Rich, that is cool, wish I was capable of tuning as I drove the car!
[Re: Hemi ragtop]
#2338279
07/17/17 11:44 AM
07/17/17 11:44 AM
Posts: 4,210 New York
polyspheric
New York
That^^^
Boffin Emeritus
[Re: Hemi ragtop]
#2338283
07/17/17 11:51 AM
07/17/17 11:51 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I have gotten 10 mpg w/ my 572" hemi and a 1200 cfm dominator.
[Re: Hemi ragtop]
#2339130
07/18/17 03:14 PM
07/18/17 03:14 PM
Posts: 48 the Netherlands
dutchrunner
the Netherlands
69RR with572 hemi StageV heads , EFIMAN cam and XFI 2.0 (F&B six-pack TPI injection) with 727 and gearvendor 3.54 gears cruising 65 mph doing 18-19 mpg
1969 Roadrunner Sox&Martin tribute with 572Hemi and F&B performance Six-Pack XFI2.0 injection.
