Tremec TKO clutches #2337979
07/16/17 08:57 PM
07/16/17 08:57 PM
central IL reg Nov 18, 1999
Stroker Offline OP
Stroker  Offline OP
I want to replace the generic clutch that a shop put in my car, since it's apart anyway.
What other applications take a 26 spline 10 1/2" clutch?
It's in a small block '72 B body.
Re: Tremec TKO clutches [Re: Stroker] #2338001
07/16/17 09:36 PM
07/16/17 09:36 PM
IN
ahy Offline
ahy  Offline
IN
I believe it is a standard GM specification. When I needed a new clutch, I called Silver Sport and they fixed me up.
Per my understanding, there are at least 4 "levels" for these clutches: 1) standard GM replacement from parts store, Rock Auto, Amazon ect. 2) standard replacement pressure plate with high clutch disc friction lining 3) high end single stage with metallic/Kevlar lining for higher torque 4) multi-disc setup.
What you need depends on what you are running... and how you run it.
Re: Tremec TKO clutches [Re: Stroker] #2338050
07/16/17 10:39 PM
07/16/17 10:39 PM
Stroker Offline OP
Stroker  Offline OP
Mine is a 26 spline 5008.
I think it's splined for a Ford but I have no idea what.
Re: Tremec TKO clutches [Re: Stroker] #2338504
07/17/17 06:05 PM
07/17/17 06:05 PM
dogdays Offline
dogdays  Offline
26 spline is great but what is the input shaft diameter? Diameter and spline count are both required to source a clutch disk.
R.
Re: Tremec TKO clutches [Re: dogdays] #2346758
08/01/17 04:14 PM
08/01/17 04:14 PM
Stroker Offline OP
Stroker  Offline OP
R.
Tremec TKO 600 size
Re: Tremec TKO clutches [Re: Stroker] #2346814
08/01/17 06:18 PM
08/01/17 06:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The TKO 600 #5008 input is 1 1/8" X 26-spline. Common to the '86-'00 Mustang GT.
Re: Tremec TKO clutches [Re: John_Kunkel] #2347053
08/02/17 12:28 AM
08/02/17 12:28 AM
Stroker Offline OP
Stroker  Offline OP
Thanks, John!
Can you recommend one for my '72?
QuickTime bellhousing, small block.
The fine folks who did my trans swap put in a stock replacement type.
Not 100% sure, but I think I'm limited to a 10 1/2" clutch w/that bell.
