69 Charger ignition cylinder removal #2337817
07/16/17 03:16 PM
07/16/17 03:16 PM
Ks
P
pullandrag Offline OP
P
Ks
OK I've put in many cylinders in many brands,but long story short owner lost key to car,I said buy a new ignition switch and key cylinder,he brings me a new switch and key,/tumbler no ignition cylinder I don't have the key to turn cylinder in switch to remove it and from what I read online the 69 cylinder is hard to come by so can the cylinder be removed from switch without key or or key and tumbler from cylinder without key,without ruining cylinder?
Re: 69 Charger ignition cylinder removal [Re: pullandrag] #2337825
07/16/17 03:25 PM
07/16/17 03:25 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
take it to a locksmith twocents
Re: 69 Charger ignition cylinder removal [Re: pullandrag] #2337830
07/16/17 03:34 PM
07/16/17 03:34 PM
Andrewh Offline
Andrewh  Offline
you basically have to pick the lock.
if you have the tools not that hard.
if not, as tjp said take it to a locksmith.
shouldn't be more than 25 bucks and they can make you the key.
done it a few times over the years.
give a few a call. the older the shop the better.
Re: 69 Charger ignition cylinder removal [Re: pullandrag] #2337836
07/16/17 03:40 PM
07/16/17 03:40 PM
Ks
P
P
Ks
OK jezz what a ordeal thank you guys very much ☺
Re: 69 Charger ignition cylinder removal [Re: Andrewh] #2337864
07/16/17 05:05 PM
07/16/17 05:05 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
?? maybe i'm not understanding the question shruggy.
to change the lock you remove the switch from the dash, on the side of the cylinder up by the lock there is a push pin release. push it in and the lock slides out?
Re: 69 Charger ignition cylinder removal [Re: pullandrag] #2337900
07/16/17 06:51 PM
07/16/17 06:51 PM
Andrewh Offline
Andrewh  Offline
the only way to push that in is if the key is in the "on" position in the lock.
Re: 69 Charger ignition cylinder removal [Re: Andrewh] #2337954
07/16/17 08:04 PM
07/16/17 08:04 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
you're probably right. havent had mine apart in 30+ years. i just remembered the 'ah hah' moment when i figured it out bow
Re: 69 Charger ignition cylinder removal [Re: pullandrag] #2337965
07/16/17 08:27 PM
07/16/17 08:27 PM
Ks
P
P
Ks
Yep owner coming in a hr I get to explain this to him thanks guys
