Re: Brand X after market world is very serious these days....Vid
[Re: Dragula]
#2337304
07/15/17 12:07 PM
07/15/17 12:07 PM
Challenger 1
Cincinnati, Ohio
IMO the aftermarket has been very serious for brand X for over 30 years now. Are you just now noticing? I built a 632 donovan block with pontiac big chief heads on it back in 1992 that made 1200 hp injected on alky. Then had a serious N2O system on it. There was no way to go that fast with 440 stuff then just like now. I did switch back to mopar when I went with a brad billet hemis. Not trying to make the small block guys mad but, after those motors above the 340 I built most recently is like a go cart engine power wise. I've built some serious motors.
[Re: Challenger 1]
#2337312
07/15/17 12:29 PM
07/15/17 12:29 PM
Posts: 12,418 Taxes & Virus's R-US, NY
Dragula
While I am not over 60, I for one would like to see some further interest from the younger folks in the Mopars...Seems like very little interest these days from the younger folks... And power adder cars are not running 9's anymore, they are running low 8's and faster.... "street" cars with power adders are running 9's with all factory parts at full weight..... I would like to see the aftermarket get behind the G3 and BBM's and continue to progress. I want to see 700hp NA G3's and 1k NA BBM as a standard with options available...Just like the heads for them, and all the different options available, progress needs to continue. I think the $7k blocks will price many of us out.....Unless we generate some real volume and help get the prices down. Eventually, like Hemi blocks, we will run out of regular production 440's and so on.....My friends and I certainly go thru a lot of parts each year...It would be nice to be able to make a phone call and get what we need instead of what we do go thru to get the parts... Its "cool" to be different..... https://www.youtube.com/watch?v=7chioaCT3Pw
[Re: Dragula]
#2337320
07/15/17 12:55 PM
07/15/17 12:55 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
How can you get the aftermarket interested when every mopar vendor that produces MOPAR parts gets bashed on one of the biggest Mopar websites??? Never gonna happen.
[Re: Dragula]
#2337325
07/15/17 01:07 PM
07/15/17 01:07 PM
fast68plymouth
So. Burlington, Vt.
How can you get the aftermarket interested when every mopar vendor that produces MOPAR parts gets bashed on one of the biggest Mopar websites??? Never gonna happen. How much influence do the people posting here have on the decisions you make when you're buying parts for one of your own builds? For myself...... It's pretty close to 0%. I like to make up my own mind about the parts I use. If some new head comes out, or new offering from a carb supplier, pistons, intake manifolds, etc...... I'll probably read the posts pertaining to the part in question....... But aside from an extremely high failure rate...... There is really very little that could be said to keep me from trying something if I thought it would do what I wanted it to.
[Re: Dragula]
#2337343
07/15/17 02:03 PM
07/15/17 02:03 PM
Posts: 370 Suffolk County, New York
1mean340
1000hp small block or big block mopar builds were a niche market to begin with, and I'd imagine it's getting even smaller with guys jumping ship to gen3. Looking for a 1000hp capable block for cheap? How about a whole fully assembled short block for under 4K? http://www.modernmusclextreme.com/p-215-hellcat-62l-hemi-short-block-68262362aa.aspxGuys are pushing their hellcats to 1000rwhp on that stock short block so I'd imagine 1000hp at the crank wouldn't be so risky (assuming you're using a turbo or blower, not spinning it to 9k N/A). This is the way I wish I went with my car. I couldn't afford to drop 2500-3k on an unmachined R block then pay another 3-4k for a rotating assembly and machine work so now my stock LA block is my limiting factor and i'm afraid to push it over 650hp. Doing the math on it, I think I could have done the late model hemi for close to the same cost and I would have had a far superior power plant, not only in its ability to make and handle power but in drivability as well.
[Re: fast68plymouth]
#2337355
07/15/17 02:21 PM
07/15/17 02:21 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
How can you get the aftermarket interested when every mopar vendor that produces MOPAR parts gets bashed on one of the biggest Mopar websites??? Never gonna happen. How much influence do the people posting here have on the decisions you make when you're buying parts for one of your own builds? For myself...... It's pretty close to 0%. I like to make up my own mind about the parts I use. If some new head comes out, or new offering from a carb supplier, pistons, intake manifolds, etc...... I'll probably read the posts pertaining to the part in question....... But aside from an extremely high failure rate...... There is really very little that could be said to keep me from trying something if I thought it would do what I wanted it to. Google is a powerful tool in today's world as we are not all old school and use it as a research tool and negative reports do come up and they do affect businesses
#2337360
07/15/17 02:26 PM
07/15/17 02:26 PM
Dragula
How can you get the aftermarket interested when every mopar vendor that produces MOPAR parts gets bashed on one of the biggest Mopar websites??? Never gonna happen. How much influence do the people posting here have on the decisions you make when you're buying parts for one of your own builds? For myself...... It's pretty close to 0%. I like to make up my own mind about the parts I use. If some new head comes out, or new offering from a carb supplier, pistons, intake manifolds, etc...... I'll probably read the posts pertaining to the part in question....... But aside from an extremely high failure rate...... There is really very little that could be said to keep me from trying something if I thought it would do what I wanted it to. Forums are for good and bad...opinions are not all one sided that's why we call it a discussion. If products we use are constantly being discontinued due to lack of volume, my opinion of it is irrelevant. Bought a $1300 sV1...you might want to know what I thought of it, is it negative to discuss the tune it came with is way off? Bought a G3 Dominator...same issue...am I not allowed to say anything because out if the box it wasn't even close?
[Re: Dragula]
#2337380
07/15/17 02:52 PM
07/15/17 02:52 PM
fast68plymouth
So. Burlington, Vt.
There's nothing wrong with discussion.
My point was........ If I wanted to try a SV1 or a new Gen3 Dominator...... I would just do it and make up my own mind........ And there wouldn't be much of anything I read on the Net that would keep me from doing that.
The argument that all new products for Mopars get bashed here, and that's why nothing new is coming out doesn't carry much water for me.
If you find the right niche, and build a quality part to fill it..... It will sell well, and get mostly positive reviews...... Even here on Moparts.
Case in point....... Trick Flow heads.
I have zero idea on how the sales numbers actually stack up...... But if I had to guess, I'd say they sold more TF Mopar heads in the last 18 months than they have sold new B1 heads in the last 5 years. And the TF head competes in a segment where there is plenty of competition.
The flip side is....... There are plenty of negative reviews for just about any brand x part you can think of. Just find the busiest web site pertaining to that brand, and you'll find it's the same story there as here. Whatever it is......... Someone loves it...... Others hate it. Whether its camshafts, cylinder heads, fast food chains, car manufacturers, cola flavored soda....... It's all the same.
[Re: Dragula]
#2337419
07/15/17 04:15 PM
07/15/17 04:15 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
While I am not over 60, I for one would like to see some further interest from the younger folks in the Mopars...Seems like very little interest these days from the younger folks... Its "cool" to be different..... https://www.youtube.com/watch?v=7chioaCT3Pw 90s Chrysler company is mostly to blame for this, IMHO. Most of my buddies from that time period were in to Mustangs and Camaro's because they were rear wheel drive, what did Ma Mopar offer in rear wheel...the Dakota and Ram, great if you wanted to beat up a Lighting or 454 truck. there was the Viper...but what real life struggling family is going to buy a viper. Neon...yeah that really got the masses interested in the performance. We as people tend to follow in our parents foot steps, Brand Loyalty accounts for about half on new car buyers , the other half is image and reliability...lets face it unless you were loyal to ma Mopar thru the bad years , Chrysler chassed away a lot of it's then new customers mid 80s thru early 2000s The 545 trans didn't help the light duty truck market either.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
#2337421
07/15/17 04:16 PM
07/15/17 04:16 PM
Posts: 524 Mesa, AZ
Bill_T
Mesa, AZ
How can you get the aftermarket interested when every mopar vendor that produces MOPAR parts gets bashed on one of the biggest Mopar websites??? Never gonna happen. How much influence do the people posting here have on the decisions you make when you're buying parts for one of your own builds? For myself...... It's pretty close to 0%. Well, I have spent more than a little over the years based not insignificantly on your posts. If the delivery times on "The Block" get down to under a month I might be in the market. It sure would be nice if they were closer to 3K than 4 though....
This space not for rent.
[Re: Dragula]
#2337434
07/15/17 04:37 PM
07/15/17 04:37 PM
fast68plymouth
So. Burlington, Vt.
Well, I have spent more than a little over the years based not insignificantly on your posts. I appreciate the vote of confidence But I really don't consider myself as the "last word" on anything....... Except the things that I'm buying for myself(or i suppose a customer build as well). For any car site with similar traffic and membership to this one, I have no doubt there are plenty of guys like myself with what I'll call "informed opinions" to share, where people put some faith in what they have to say.
[Re: Dragula]
#2337712
07/16/17 11:37 AM
07/16/17 11:37 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
I don't do power adder deal for my stuff period. And still want 1000+hp. Leave the choices few and far between. Also leaves all the little things to be done. Cant just but some bits and pieces and "throw" them together. There is enough BBC stuff out there that you could piece together a bad combo and not worry about the details and still make 1000+, that to ne is the biggest difference between the two.
383man you are by far in the majority of what I see at most Mopar shows. Guys just want to have fun and be at the track racing. And they are perfectly happy there and there is nothing wrong with that at all. It is obviously what drives the market..
As for any commentary here on products and their possible influence on the market. I think some here think this place is the be all and end all of the Mopar world. I would say it is VERY VERY far from that. This place is but a VERY SMALL portion of the Mopar community, very very small really. Especially amongst the racing community. Most work hard and don't have the time to spend hashing crap over on an internet forum, I have time as I retired for the most part at 47, six years ago. To think that Moparts has a big impact on any aftermarket development of parts is well in my mind arrogant. As for people basing ANYTHING, I think you will find people are very quick to criticize and complain about anything and a lot more hesitant to compliment or shower praise on any business. We fight it all the time..One person with an axe to grind will continue on their rant and diatribe to no end if they feel they were wronged, whether they were or just perceive they were. I personally take all reviews with a grain of salt, to many years on business I suppose..
[Re: ccdave]
#2337717
07/16/17 11:47 AM
07/16/17 11:47 AM
Posts: 19,631 north of coder
moparx
being in my mid 60's, i'm like 383man. i still think of the 62-3 &4's as new cars. and getting my charger in '70, well, it WAS new [almost]. i really like the new, super powerful stuff of today, including the hell cat and demon, plus the availability of the aftermarket parts that can produce [in the right combination] 1000+hp. but with my age comes severe health problems that take up a fair share of my limited income, so i have resigned myself to the fact i will never be "there" in either respect mentioned previously. with that being said, i need an engine for my 33 dodge humpback panel truck, and i also need an engine "refresh" for my charger. if, and when, the time comes for either of those, i have performance goals that i truly believe each must obtain just because of the "look" of each. at that time, i will trust this board with recommendations, and possibly try to purchase a long or short block for a very good price i can afford, rather than build one from scratch. my best friend always says : "our hour glass is fast running out of sand". it won't be a new conversion, rather an "old school", carbed combo combination that "may" meet my goals at the weight of each vehicle.
[Re: Dragula]
#2339156
07/18/17 03:52 PM
07/18/17 03:52 PM
Posts: 1,467 Martinsville, IN
cdwmotorsports
Martinsville, IN
I turned 43 less than a month ago and I love my 451" Demon but it gets harder and harder to find time, money and desire to work on it. The engine has been in the garage for almost a year ready to go back in yet it is still there. More and more tempting to unload it and move on.
eBay-cdwmotorsports
