Page 9 of 10 1 2 7 8 9 10
Re: 383 HP 330vs335 hp [Re: 383man] #2333047
07/07/17 01:09 PM
07/07/17 01:09 PM
pa.
dan9 Offline
dan9  Offline
pa.
Thank you for clearing that up for me. Back then we had to rely on the car mags for info. It seems like the older these cars get the more people know about them. The mags back then said the 70 motors were smog motors and rated at less hp.
Re: 383 HP 330vs335 hp [Re: Bad B-rad] #2333103
07/07/17 02:59 PM
07/07/17 02:59 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Several years ago a buddy of mine who owns a flow bench did a flow comparison between the various exhaust manifolds. The test was done out of curiosity and from a similar thread on moparts posted at the time. The test was to measure flow and port velocity. The manifolds tested were the B body magnum driver side, C Body magnum Driver side and my 68 GTS 383 driver side manifold. All the subjects were tested at 25" of Vacum. All the exhaust ports were tested to come up with an average
Both the B and C manifolds flowed within 5" of each other. Both had the heat riser with the flap wide open. The A Body driver side manifold flowed slightly less on average between the B and C. The number wasn't significant. It had the heat riser removed.
Of course I went looking for the charts in all my stuff that's still unpacked from our move two years ago and have yet to find them. I'll be going up north next month where I can get copies to post.
Abe Lincoln
Re: 383 HP 330vs335 hp [Re: dart4forte] #2333163
07/07/17 04:31 PM
07/07/17 04:31 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
So do you mean passenger side? The drivers side did not have heat risers. shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: 383 HP 330vs335 hp [Re: 383man] #2333193
07/07/17 05:18 PM
07/07/17 05:18 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Originally Posted By 383man
Originally Posted By dan9
If I remember correctly the ads or road tests of the new RR and Super Bee stated that they came with 440 heads. Maybe that lead to a a lot of confusion. I have old mags from the era and I am curious about what they said.
I remember reading that in a 68 Roadrunner add. And the reason being up to 1968 the 383 and 440 had different heads. After that as far as I remember both the 383 and 440 used the same 906 head up to 1970. But before 1968 the 383 used the small 1.60 exh valve heads and the 440 the 1.74 exh valve heads.
I believe in 1967 the 383 in the A-body (Dart & Cuda) that was rated at 290 hp used the small valve 1.60 heads and the 383 two brl cam. I think in 1968 the A-body 383 got the large valve 906 heads and the 300 hp rating and in 1969 the 383 A-body got the better 383 Roadrunner/SuperBee cam and the 330 hp rating. All in all it sure can get confusing. Ron
On the 67 440 engine, hp=big ex valve, lp=small ex valve. Dad bought a 67 New Yorker for parts for his car, came with the 440-2 barrel 915 head small valve. I Had the big valve installed and used them on my 69 383. I think 67 was the first year for the big ex valve on a production engine (GTX type) Dads NYorker had the 375 engine in it, same as GTX-RT
Re: 383 HP 330vs335 hp [Re: cudaman1969] #2333454
07/08/17 03:54 AM
07/08/17 03:54 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
No such thing as a 2bbl 440, but I think you're right on the standard '67 440 having 1.60" exhaust valves in 915 heads.
Re: 383 HP 330vs335 hp [Re: cudaman1969] #2333630
07/08/17 02:42 PM
07/08/17 02:42 PM
pa.
dan9 Offline
dan9  Offline
pa.
Not to change the subject but I thought the 440's in Chryslers were 350hp.
Re: 383 HP 330vs335 hp [Re: dan9] #2334839
07/10/17 05:25 PM
07/10/17 05:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
350HP std , 375HP optional in some models.
Re: 383 HP 330vs335 hp [Re: Alchemi] #2334841
07/10/17 05:37 PM
07/10/17 05:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
[quote=Alchemi]I have a 68 non hp 2bbl short block sitting assembled with new rings and bearings, I can not say for sure that the deck is untouched, but I do have a couple of pistons proud of the deck, they are dished
I will get some pics up soon [/quote
Did you check them all? I have the same piston right here next to me and the the only way it would be above the deck is if either the factory cut the block too much originally, which isn't the norm as they are usually tall, or someone cut it to square during a rebuild. Is the factory stampings still intact on the front pass side ID pad ?
The CH of that piston is 1.932, same as the HP flat top, and on a blueprint spec block deck it is .0025 in the hole .
Re: 383 HP 330vs335 hp [Re: JohnRR] #2335198
07/11/17 10:25 AM
07/11/17 10:25 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
JohnRR the pad looks intact
D383
3 1 2
its a 67 casting date and only has a number stamped on the bottom of the bellhousing under the starter
It had been apart prior to me, one of the 906 heads ended with a -1 and the other -5
Recently it has been honed and the pistons/rods bead blasted, crank polished, machinist said a couple of pistons were down a few thou, and a couple of bores slightly larger (when I did ring gap, 2 ended up .004-5 bigger)
When I originally pulled the motor down a couple of years ago I checked the deck heights with a single piston and got not identical but similar results to below, that piece of paper long gone though
The odd side was at 0 ish - I could get .003 up on #1 giving it a tap with a dowel and 2 others less, but #5 is just under
Pad side however is way off
2 - 0, +.004T
4 - +.003, +.0075T
6 - +.0025, +.007T
8 - +.005, +.008T
If that side was machined, it was done very poorly compared to the other side (and would explain the intact pad?) After looking at how both 5&6 seem a bit lower than the neighbors id say I lost a thou or two on the crank polish and 6 must be a loose piston with the high tilt value
Machinist said I would have a bit of piston slap when cold and not to race it.... plans changed - it was thrown together to get the car moving, but now has much better internals collating. Wondering how it would go with some sidewinders and 2 different gasket heights, run it till it blows and then put the good stuff in... lols
Re: 383 HP 330vs335 hp [Re: Rhinodart] #2335427
07/11/17 06:07 PM
07/11/17 06:07 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
No, we did the driver side. I just mis-spoke. Guess I had passenger side on the brain. Still digging through my stuff. I did find the flow numbers on the heads on the 68 GTS.
Abe Lincoln
Re: 383 HP 330vs335 hp [Re: Alchemi] #2335960
07/12/17 03:06 PM
07/12/17 03:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
D383
3 1 2
2 - 0, +.004T
4 - +.003, +.0075T
6 - +.0025, +.007T
8 - +.005, +.008T
Can you post a picture of the pad area ? The fact that the info is still thetre tells me it was either purposely machined like that and you would see a step , I have had a couple of 383's decked on a Rottler CNC and specifically asked that the ID pad not have the info machined off.
If you are expecting all the pistons to be the same depth from cylinder to cylinder you are expecting way too much from that engine. It MIGHT have been pretty close when it was new but after x number or hundreds , or even thousands of heat cycles?
I'm still surprised that you have positive pistons , are you measuring with a deck bridge directly over the center of the pin or out at an edge and rocking the piston?
Do you have a way to measure from the crank centerline to the top of the deck on the 4 corners ?
Re: 383 HP 330vs335 hp [Re: JohnRR] #2336061
07/12/17 06:16 PM
07/12/17 06:16 PM
I've seen .018 in rod center to center length in stock rods, not in the same motor though work puke
Re: 383 HP 330vs335 hp [Re: 68mannix] #2338494
07/17/17 05:48 PM
07/17/17 05:48 PM
Georgia
1969383S Offline
1969383S  Offline
Georgia
All A-Body 383 cars in 69 at least, had Windage trays as well. See Attached. So it is doubtful the extra 5 comes from that alone. I think it is more a market game played by Ma Mopar.
Attached PDF document
pan and windage info.pdf (169 downloads)
Gerald
Re: 383 HP 330vs335 hp [Re: 1969383S] #2339430
07/19/17 12:20 AM
07/19/17 12:20 AM
Georgia
1969383S Offline
1969383S  Offline
Georgia
The only difference is in the manifolds used and the block configuration. The internals were all the same!
Maybe the model AVS Carb was different as 2 models are listed for each Stick and Auto
A-Bodies were "S" block builds. (Machined off Left side rear engine mount ear and drilled bosses at the oil pump for left side mount, chrome covers and oil breather.) Hemi Orange
RR and SB were "H" block builds (Normal Engine Mount ears no drilled boss at the oil pump.) Hemi Orange
It was nothing but marketing! They both have HP stamps on boss under the Dizzy.
Were they going to tell the buyers the Barracuda or Dart had the same power in an economy car as the highly marketed Road Runner or Super Bee mid size cars? Heck no, you spin it. The loss in advertised HP on the A-body left manifold was easily gained in weight loss of the car. A-body 383 cars rule!
See Attached.
Gerald
Re: 383 HP 330vs335 hp [Re: 1969383S] #2339523
07/19/17 04:28 AM
07/19/17 04:28 AM
Me thinks your confusing the M code 1969 A body 440 mounts with the H code 383 A body cars, the 440 had the oil pump bosses drilled and tapped, the 383 did not scopeThe A body 383 blocks from 1967 to 1969 had two bosses cast into the driver side block that where drilled and tapped for the block steel motor mount to bolt to, no cast in motor mounts ears machine off either shruggy
I've had two 383 A body cars that where original and seen several original M code 1969 440 A body cars, there are differences in them on the block machining and exhaust manifolds shruggy
Re: 383 HP 330vs335 hp [Re: Cab_Burge] #2339571
07/19/17 10:17 AM
07/19/17 10:17 AM
fredericksburg,va
fredericksburg,va
Also my 69 RR 383 block has those cast bosses for the mounts used in the a-body's .
Re: 383 HP 330vs335 hp [Re: Cab_Burge] #2340310
07/20/17 01:24 PM
07/20/17 01:24 PM
Georgia
1969383S Offline
1969383S  Offline
Georgia
I meant to say above the oil pump for the front mount bosses. Drilled and Tapped
A-body 383 left mount attaches to those 2 bosses above the pump and the front ear. The rear Ear for normal mounts used in RR/SB etc is machined off. Attached is a genuine A-body Block.
Gerald
Re: 383 HP 330vs335 hp [Re: NachoRT74] #2340795
07/21/17 03:43 AM
07/21/17 03:43 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Found this info about 383's from 1970. Ron
Re: 383 HP 330vs335 hp [Re: 1969383S] #2340900
07/21/17 12:09 PM
07/21/17 12:09 PM
fredericksburg,va
fredericksburg,va
Cool, learn something new everyday. Been a long time, but working on my buddy's 68 383 Darts (had two 383 GTS's, one auto, one 4-speed) can't remember seeing that, we removed engines and put on the stand to go thru.
Re: 383 HP 330vs335 hp [Re: 383man] #2340904
07/21/17 12:15 PM
07/21/17 12:15 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Thanks much Ron. I didn't realize the Road Runner 383 was different than the Super Commando 383. Back in 70, I bought a 'Cuda 383 4spd new & it had the Super Commando that I thought had the same motor as my friends new Road Runner.
