Re: Weird MoPar interchangability.....
[Re: romanucci]
#23357
02/08/06 10:50 AM
02/08/06 10:50 AM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
2.2L K car alternator with V belt. Direct bolt in.
hmmm what output rating do they have .
I'm curious about that one, too. Does the K-car alternator still have an external regulator? Is it one field wire or two?
It's probably just the same as most any of the square-back ALT's. It's two wire, and externally regulated. Probably something like 60A, which is about what you get from the parts hous if you ask for a 74 Swinger 318 with A/C...
My 86 Shelby Charger uses a similar looking ALT, also square back and dual wire externally regulated. It's got a thin metal ring in the middle, like 1/8" wide, where the "normal" old-skool ALT is about 1/2" wide. This is supposedly a higher-rated ALT, but I don't recall how high. That one would require a pulley swap, but I bet it's a direct swap. FWIW, the power module behind the battery is what controls the ALT output. Mine took a dump a bunch of years ago, and I simply pulled the two wires that that ran the ALT and plugged them in to a typical fender-mount electronic regulator. Worked great for a few years until I found another good PM.
Also, the REAR dust caps, nuts, key washers, and adjuster nuts on Dodge Daytonas (87-89 at least) are perfect fits for the FRONT dust caps on big bolt pattern disks, AKA, Darts, Challengers, and the cop rotors.
Clair
#23358
02/08/06 11:28 AM
02/08/06 11:28 AM
Posts: 806 Belle Mead, NJ
65Frank
super street
super street
Belle Mead, NJ
Turn signal switch and canceling cam from up to 1976 Dodge Vans will work in a 65' Coronet Steering column.
With no modification? Do you know the Part number? Would like to try that at a dealer.
[Re: 65Frank]
#23359
02/08/06 11:37 AM
02/08/06 11:37 AM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
Me three!
[Re: KillerBee]
#23365
02/08/06 02:38 PM
02/08/06 02:38 PM
thats a great one killer bee! Thank you!! I didnt know that. Do you know about the same dodge truck years for the side parking light or marker light. I think they fit 71?-75 b-bodies as well.
#23366
02/08/06 03:27 PM
02/08/06 03:27 PM
Posts: 16,837 Between Houston & Galveston TX
SattyNoCar
Heater controls (the dash mounted part) will swap between late '70's B-bodies and early '80's trucks with no mods at all. I had an '84 PU that I swapped in the controls from a '76 Fury.
John
[Re: Barnabas_Kriss]
#23370
02/10/06 11:48 AM
02/10/06 11:48 AM
Was there a post like this some time ago. This is great stuff.
