Re: Mechanical fuel pump question
[Re: Mattax]
#2334223
07/09/17 04:30 PM
07/09/17 04:30 PM
Posts: 26,841 Rio Linda, CA
John_Kunkel
Rio Linda, CA
That was my first thought, too. I guess you can take the Studebaker from the boy but you can't take the Studebaker out of the boy.
[Re: Ramrod39]
#2334602
07/10/17 10:26 AM
07/10/17 10:26 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not a weep hole.
It's a vent for the diaphragm, nothing more. You only want pressure or vacuum on one side of the diaphragm, the fuel side.
[Re: Ramrod39]
#2334610
07/10/17 10:36 AM
07/10/17 10:36 AM
Posts: 21,129 Niles , Ohio
therocks
Niles , Ohio
Putting fuel pumps on Mopars since the 60s.Never ever saw one with a fitting like that.Guess it would not hurt but sure is strange.One reason I use Holleys.had like 3 bad carters that were total junk.Rocky
Chrysler Firepower
[Re: Mattax]
#2334735
07/10/17 01:50 PM
07/10/17 01:50 PM
John_Kunkel
Rio Linda, CA
A lot of different fuel pumps that share the same mounting pattern use the same castings. If the nipple was a "breather" that means the top of the diaphragm would be isolated from the engine crankcase but they're normally exposed to the crankcase...that's where they "breathe". A shot of the lever end might show if it's isolated. The only time I've seen a nipple in that location is for supercharger reference i.e. when the supercharger boost exceeds the pump pressure, the supercharger boosts the spring in the pump.
[Re: Supercuda]
#2334910
07/10/17 07:10 PM
07/10/17 07:10 PM
Posts: 270 Missouri
Big_E
Missouri
Not a weep hole.
It's a vent for the diaphragm, nothing more. You only want pressure or vacuum on one side of the diaphragm, the fuel side. Still it's a "hole" that will "weep" or "vent" fuel when your pump goes bad.
[Re: Big_E]
#2334960
07/10/17 08:54 PM
07/10/17 08:54 PM
Supercuda
About to go away
About to go away
up yours
Not a weep hole.
It's a vent for the diaphragm, nothing more. You only want pressure or vacuum on one side of the diaphragm, the fuel side. Still it's a "hole" that will "weep" or "vent" fuel when your pump goes bad. If you get a leak out that hole your first indication will be a non-running engine followed by an oil pan full of gasoline. BTDT with no leak out that hole whatsoever.
[Re: John_Kunkel]
#2334964
07/10/17 09:03 PM
07/10/17 09:03 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Probably not visible without partial disassembly. The seal appears to be on top of the diaphram spring. Agree that would be the difference between a boost ref for supercharger and vent line for something like marine use.
[Re: Mattax]
#2335078
07/10/17 11:23 PM
07/10/17 11:23 PM
Posts: 9,271 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
Probably not visible without partial disassembly. The seal appears to be on top of the diaphram spring. Agree that would be the difference between a boost ref for supercharger and vent line for something like marine use. It is actually listed as a marine fuel pump...
