Re: Steering coupler kit still available at dealershi [Re: NachoRT74] #233320
02/25/09 03:24 PM
02/25/09 03:24 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
I made on engine bay. Once mounted the hardest part is really clamp the metallick cover.
I didn't change the cross stud though
Do the 3 bolts have to come out where the column braces to the firewall?
Darren
Re: Steering coupler kit still available at dealershi [Re: Ludington1] #233321
02/25/09 04:47 PM
02/25/09 04:47 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
mmmm... one detail, mine being a 74, does have an intermediate shaft with a rubber coupler ( thin one, not the thick piece ) what I can remove from the main steering shaft on column without touch anything from firewall.
I guess with one piece shaft, will need to loose the column anyway
Re: Steering coupler kit still available at dealershi [Re: Snoopy] #233322
02/25/09 05:04 PM
02/25/09 05:04 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
One more tip that'll help you 50% of the time if you don't know about it..
some help here
Steering coupler kit available at dealerships- yes [Re: NachoRT74] #233323
02/25/09 11:10 PM
02/25/09 11:10 PM
Philadelphia
waginator Offline
waginator  Offline
Philadelphia
That part number that snoopy posted-- I bought it and the exact contents are in the plastic bag--
Cost me $8.95
Bought it at the Dodge dealership on Roosevelt Blvd. about 2 miles from me Oh Yeah!!!
Gregg
Philadelphia
1973 Imperial Lebaron
Imperial-
It's not a C body
Its not a Chrysler
Re: Steering coupler kit available at dealerships- yes [Re: waginator] #233324
03/03/09 04:20 PM
03/03/09 04:20 PM
Maine
itali83 Offline
itali83  Offline
Maine
Is this for power steering? I've heard there is a difference, if so, does anyone know the factory part number for a manual steering coupler? Thanks and the rest of this has been very helpful to me in my rebuilding/converting my steering shaft!
Also, has anyone replaced the pin that goes in the shaft itself? I tried and it's pressed in really hard, I started to burr the end over, I even heated the shaft and it still won't punch out. Now I've got to get it out as the pin is ruined. I have a press but I was wondering if others have had a problem or just never needed to do it. Thanks again!
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
Re: Steering coupler kit available at dealerships- yes [Re: itali83] #233325
03/03/09 05:29 PM
03/03/09 05:29 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Is the pin tapered?
Re: Steering coupler kit available at dealerships- yes [Re: Snoopy] #233326
03/03/09 07:02 PM
03/03/09 07:02 PM
Maine
itali83 Offline
itali83  Offline
Maine
It is a straight pin, or should I say was. I'll get it out one way or another now that I know it comes in a rebuild kit. But I just want to make sure I get a kit for a manual box adapter if still possible from the dealer or whoever really (I just like the simplicity and cost of the deal route. Thanks again.
Re: Steering coupler kit still available at dealerships? [Re: Blakcharger440] #233327
03/03/09 08:33 PM
03/03/09 08:33 PM
hey-If you have the most recent 3 issues of Mopar Action (or at least Aprils)from steer to eternity is full of good tech.
Re: Steering coupler kit available at dealerships- yes [Re: itali83] #233328
03/04/09 01:35 PM
03/04/09 01:35 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
the diff between manual and powered box coupler is the cupler itself, not internals... spline stud is bigger on manual boxes so then the coupler, but keeping same internals.
I tried to replace the pin on shaft, but noticing how hard is pressed in, simply decided not to replace. Anyway thats a piece that is really hard to worn out. Shoes and retaining spring are the REAL pieces to replace.
BTW the spring mounts by a side of shoes, not in front of shaft/shoes like the first diagram shows
Re: Steering coupler kit available at dealerships- yes [Re: NachoRT74] #233329
03/04/09 01:41 PM
03/04/09 01:41 PM
Maine
itali83 Offline
itali83  Offline
Maine
So does anyone know a part number for a manual coupler or where to get it aftermarket?
Re: Steering coupler kit available at dealerships- yes [Re: itali83] #233330
03/04/09 04:34 PM
03/04/09 04:34 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
there was a Mopar seller on line www.buymopar.com but apparently they are not anymore on line. They had it on sale
Re: Steering coupler kit available at dealerships- yes [Re: NachoRT74] #233331
03/04/09 04:51 PM
03/04/09 04:51 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
even you already got teh kit... here is one complete assembly being sold as MANUAL
http://cgi.ebay.com/ebaymotors/MOPAR-Ste...p4506.m20.l1116
( and from the pic, does loot it is )
Re: Steering coupler kit available at dealerships- yes [Re: NachoRT74] #233332
03/04/09 05:06 PM
03/04/09 05:06 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
or use an adapter:
PP4510637 $162.95
http://www.mopartsracing.com/parts/dtrain.html
Re: Steering coupler kit still available at dealershi [Re: 340dart4spd ] #233333
03/04/09 06:42 PM
03/04/09 06:42 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
this will solve any problem
It might solve problems with the OEM coupler but it will create future steering column problems.
