Re: Racing vs. standard oil filters for 318/340
[Re: 69/70 Plymies]
#2330875
07/03/17 06:51 PM
07/03/17 06:51 PM
RapidRobert
the 51515R is a full flow no bypass 60 microns. what filter are you thinking of going to? we need the microns of it.
[Re: RapidRobert]
#2330927
07/03/17 07:16 PM
07/03/17 07:16 PM
Posts: 4,704 Wichita
GY3
Wichita
[Re: RapidRobert]
#2331045
07/03/17 10:33 PM
07/03/17 10:33 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
the 51515R is a full flow no bypass 60 microns. what filter are you thinking of going to? we need the microns of it. it is a bypass, from Wix 8-11 psi bypass
[Re: CSK]
#2331077
07/03/17 11:25 PM
07/03/17 11:25 PM
RapidRobert
the 51515R is a full flow no bypass 60 microns. what filter are you thinking of going to? we need the microns of it. it is a bypass, from Wix 8-11 psi bypass then I copied (& posted) some wrong information
[Re: RapidRobert]
#2331149
07/04/17 02:26 AM
07/04/17 02:26 AM
Posts: 137 midwest - USA
69/70 Plymies
midwest - USA
the 51515R is a full flow no bypass 60 microns. what filter are you thinking of going to? we need the microns of it. I was told the standard WIX #51515 was 21 micron.
[Re: Kern Dog]
#2331256
07/04/17 11:41 AM
07/04/17 11:41 AM
Posts: 6,570 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Would someone please explain "bypass" ? Does this mean the amount of pressure that gets UNfiltered and just passed through the system ? It's a safety valve that bypasses the filter if the oil is too cold/thick to flow thru or if it was to clog for whatever reason. Better that unfiltered oil goes to the crank than no oil at all. Kevin
[Re: 69/70 Plymies]
#2332794
07/06/17 10:58 PM
07/06/17 10:58 PM
Posts: 1,768 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I've been using WIX 51068 on my 360 motor since having started it after a fresh rebuild. As best as I can tell it is still all-good. Some filter specs: By-Pass Valve Setting-PSI: 8-11 Anti-Drain Back Valve: Yes Beta Ratio: 2/20=6/20 Burst Pressure-PSI: 275 Max Flow Rate: 7-9 GPM Nominal Micron Rating: 21
[Re: 69/70 Plymies]
#2338293
07/17/17 12:06 PM
07/17/17 12:06 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
http://www.wixfilters.comLook at the specs for 51515R vs 51515 R has more GPM and less filtration than the street duty one
