Racing vs. standard oil filters for 318/340 #2330732
07/03/17 03:53 PM
07/03/17 03:53 PM
midwest - USA
69/70 Plymies Offline OP
midwest - USA
If an engine was built for mild drag racing and using a Wix oil filter rated for racing (#51515R), can I use a standard filter without any concerns and will the oil pressure be higher? The engine runs at 60 psi with the racing oil filter. Thanks for the help.
Re: Racing vs. standard oil filters for 318/340 [Re: 69/70 Plymies] #2330768
07/03/17 04:54 PM
07/03/17 04:54 PM
okla.
sam64 Offline
sam64  Offline
okla.
I run a wix 51515 on my race car 70 psi.
Re: Racing vs. standard oil filters for 318/340 [Re: 69/70 Plymies] #2330875
07/03/17 06:51 PM
07/03/17 06:51 PM
the 51515R is a full flow no bypass 60 microns. what filter are you thinking of going to? we need the microns of it.
Re: Racing vs. standard oil filters for 318/340 [Re: RapidRobert] #2330927
07/03/17 07:16 PM
07/03/17 07:16 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Check out Baldwin
Re: Racing vs. standard oil filters for 318/340 [Re: RapidRobert] #2331045
07/03/17 10:33 PM
07/03/17 10:33 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
it is a bypass, from Wix 8-11 psi bypass
Re: Racing vs. standard oil filters for 318/340 [Re: CSK] #2331077
07/03/17 11:25 PM
07/03/17 11:25 PM
then I copied (& posted) some wrong information
Re: Racing vs. standard oil filters for 318/340 [Re: RapidRobert] #2331149
07/04/17 02:26 AM
07/04/17 02:26 AM
midwest - USA
midwest - USA
I was told the standard WIX #51515 was 21 micron.
Re: Racing vs. standard oil filters for 318/340 [Re: 69/70 Plymies] #2331184
07/04/17 05:18 AM
07/04/17 05:18 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Would someone please explain "bypass" ? Does this mean the amount of pressure that gets UNfiltered and just passed through the system ?
Re: Racing vs. standard oil filters for 318/340 [Re: Kern Dog] #2331256
07/04/17 11:41 AM
07/04/17 11:41 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
It's a safety valve that bypasses the filter if the oil is too cold/thick to flow thru or if it was to clog for whatever reason.
Better that unfiltered oil goes to the crank than no oil at all.
Kevin
Re: Racing vs. standard oil filters for 318/340 [Re: 69/70 Plymies] #2331520
07/04/17 07:09 PM
07/04/17 07:09 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
http://www.jomarperformance.com/pro-filter.php
These are what I used before installing a permanent filter.
You can tell when the filter starts not flowing as well by the oil pressure gauge dropping off.
I cut my filters apart to see what's in them, these are built really well compared to some others.
Re: Racing vs. standard oil filters for 318/340 [Re: 69/70 Plymies] #2332794
07/06/17 10:58 PM
07/06/17 10:58 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I've been using WIX 51068 on my 360 motor since having started it after a fresh rebuild. As best as I can tell it is still all-good.
Some filter specs:
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Re: Racing vs. standard oil filters for 318/340 [Re: 69/70 Plymies] #2338284
07/17/17 11:52 AM
07/17/17 11:52 AM
midwest - USA
midwest - USA
I just read on the box of a WIX 51515R (Racing filter) and it says, "Warning: Not for street use". What is this all about? I just changed the oil and circumstances caused me to install a race filter, so should I be using this filter if the car is now being used for street use only?
Re: Racing vs. standard oil filters for 318/340 [Re: 69/70 Plymies] #2338293
07/17/17 12:06 PM
07/17/17 12:06 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
http://www.wixfilters.com
Look at the specs for 51515R vs 51515
R has more GPM and less filtration than the street duty one
Don't be the exception.
