Re: DRAG RADIALS
[Re: VIPERDUST]
#2331262
07/04/17 12:00 PM
07/04/17 12:00 PM
Posts: 8,374 fredericksburg,va
cudaman1969
fredericksburg,va
My buddy runs a Hoosier 30x9x15 radial on his H/Stock auto car. He pulled the axels out to change gear and the axels splines where twisted about 3/16 inch, which means, dead hooking is hard on parts. Just saying, but im still planning on running them on my F/Stock Duster and all of the Stocker guys run them.
Re: DRAG RADIALS
[Re: VIPERDUST]
#2331269
07/04/17 12:14 PM
07/04/17 12:14 PM
Posts: 11,732 Portage,michigan
B3422W5
Portage,michigan
I loved those 275 radial Hoosiers i had on my Duster Matt. It only ran high 11's, but the 60 foot was ultra consistent from one outing to the next. And that with cheap shocks front and back. Got two years out of the last pair, wifh a good bit of street driving thrown in. They are very light and hook extremely well with a very light burnout. Ran 18 in them at the track.
Re: DRAG RADIALS
[Re: VIPERDUST]
#2331874
07/05/17 01:13 PM
07/05/17 01:13 PM
B3422W5
Portage,michigan
17317 is the Hoosier 275 part number. The 295 has a 94.5 runout, likely a good bit taller than what you can fit.
