T/A Block Overbore #2327581
06/27/17 04:39 PM
06/27/17 04:39 PM
Ohio
RestoreCuda Offline OP
Ohio
Does anyone have experience with safely boring a T/A block more than 0.060 over? I have one who's sonic testing is good but has been sitting and the cylinder walls are very pitted.
Re: T/A Block Overbore [Re: RestoreCuda] #2327594
06/27/17 05:03 PM
06/27/17 05:03 PM
dogdays Offline
dogdays  Offline
I believe the question for you is, how will the sonic test be after boring to remove the pitting?
T/A blocks are not falling out of trees. Especially if the car it belongs to still exists.
In this age of custom pistons any bore size is available as long as rings exist for the size. Meaning if it needed to go 0.017 over there's no reason to go another 0.020. 4.117? Easy as asking Summit...https://www.summitracing.com/parts/slp-e-297x60/overview/
R.
Re: T/A Block Overbore [Re: RestoreCuda] #2327927
06/28/17 09:41 AM
06/28/17 09:41 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I would be shocked if it would even make a .060. I had a ta block at .030 and it sonic tested so bad, I was afraid to go .060. They are not any thicker than a regular 340. No way would I go .080. I've had a regular 340 pinhole at .060. Good luck with it.
Re: T/A Block Overbore [Re: fastmark] #2327931
06/28/17 09:48 AM
06/28/17 09:48 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
If it's a numbers matching deal sleeve it. If you just want to use it for a street or race engine sell it to the resto crowd and get another block.
Re: T/A Block Overbore [Re: fbs63] #2328136
06/28/17 04:56 PM
06/28/17 04:56 PM
dogdays Offline
dogdays  Offline
Great advice and what I should have said in the beginning.
It's a pity that this block has a stouter bottom end than a regular 340 but what you gonna do? It's worn out.
R.
Re: T/A Block Overbore [Re: RestoreCuda] #2328139
06/28/17 05:03 PM
06/28/17 05:03 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
8 sleeves are really not that expensive. The TA block is expensive.
Re: T/A Block Overbore [Re: NANKET] #2328144
06/28/17 05:09 PM
06/28/17 05:09 PM
an8sec70cuda Offline
iagree I'd sleeve the bad holes and keep the rest at either .030" or .040" max overbore if possible. Sell the T/A block to someone restoring one of those cars. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: T/A Block Overbore [Re: an8sec70cuda] #2328368
06/29/17 12:24 AM
06/29/17 12:24 AM
NY
LTLBEE Offline
LTLBEE  Offline
NY
What is the VIN number on the block? A lot of AAR & TA owners are looking for there original engines.
I'm still looking for mine. it's a needle in a haystack but you never know.
Re: T/A Block Overbore [Re: LTLBEE] #2328496
06/29/17 10:53 AM
06/29/17 10:53 AM
Ohio
Ohio
Thanks to everyone for the input!
There is no VIN on the block. It is a replacement block.
Thanks again
